Creaky struts? - Page 2 - Subaru WRX Forum
post #16 of 31 Old 01-02-2013, 10:57 AM
Teins are harsh and bouncy, due to the fact that they are not valved properly for poor US road conditions and known for rusting, causing the adjustments to seize.
If you're not racing on a competitive basis, coilovers are a waste of money due to the costs involved in getting a good setup, highly redundant adjustability given street use, higher levels of maintenance (they require upkeep , periodic rebuilds, and removal every winter where as struts are maintenance free), and reduced reliability compared to struts. If you can't out drive your struts and springs, you may not be spending your money as well as you can.
post #17 of 31 Old 01-02-2013, 02:35 PM
Originally Posted by BoostBum View Post
It won't be any time soon that I'll be able to aford them but I was thinking maybe Tein coilovers. And its my everyday driver so I don't do nothing major.
Forget coilovers and just replace the struts. That would be a waste of money on a daily driver.
post #18 of 31 Old 01-09-2013, 04:22 PM Thread Starter
BoostBum is an unknown
Well I do want reduce the gap in between the wheel and the fender. Would I just need lowing springs?
BoostBum is offline
post #19 of 31 Old 01-09-2013, 05:42 PM
Then don't do tein coilovers. Matter a fact, I'd steer completely away from coilovers and do a nice spring strut combo.
Look into TIC.
post #20 of 31 Old 01-09-2013, 05:48 PM
If you want to drop it the correct way, check out a RCE yellow spring with a strut built to match. Again, you can find a good set up at TIC
post #21 of 31 Old 01-11-2013, 02:41 PM Thread Starter
I looked at TIC. I'll probably end up ordering from there.
Do you know how much the yellow springs will drop the ride height? I don't really care to drop to far I just don't want to look like I'm on stilts anymore haha.
BoostBum is offline
post #22 of 31 Old 01-11-2013, 03:51 PM
Yellows are a little too harsh for GD Imprezas, esp if it's a DD. I would opt for Swift Rs are RCE Blacks.
post #23 of 31 Old 01-14-2013, 09:51 AM Thread Starter
How do you mean the yellows would be to harsh?
And I did some searching and found a thread on NASIOC that has pics of a bugeye with the look I would like. It's the silver bugeye in the third form the last post.
Here's the link:
Request - want to see your bugeye on RCE Black & Yellow Springs - Page 3 - NASIOC
BoostBum is offline
post #24 of 31 Old 01-14-2013, 11:05 AM
BoostBum, springs have a specific springrate and a specific height. The suspension of your car is designed for a specific throw. If you want to "do it right", you increase spring rate in proportion with the drop. You can drop without the right springrate adjustment, but that's a visual mod that will adversely affect your handling. The resultant springrates from a substantial drop "done right" are quite high, that's all brfatal is getting at. Stiff springs are not much fun on a bumpy road.
I'd get the yellows though with d-spec struts. If you decide you care more about ride quality than 0.5" visual drop later on, the yellows are easy to sell and can be replaced with blacks on the same struts (though you will need to re-align the car again). They will substantially improve handling on a good bit of road (read: track) and deliver the visual you're looking for. If your priorities change later, you're not SOL.
post #25 of 31 Old 01-14-2013, 11:06 AM
Here's the link:
Too much of a compromise away from ride comfort. They are too jarring for many, especially if you regularly drive around with non-car people in your WRX. I have Swift Rs, which are only slightly less aggressive and my girlfriend sometimes gets motion sickness in my car.
post #26 of 31 Old 01-14-2013, 11:08 AM
I like the stock 04 STi springs. Even the 07 STi springs are too stiff for passengers IMHO.
post #27 of 31 Old 01-14-2013, 06:03 PM Thread Starter
I have no problem with giving up a little visual for ride quality. And when the time comes ill go with the blacks instead of waiting money. And on Tic they give the option for group n top hats camber plates and all that. I plan on getting the top hats but should I get anything else?
BoostBum is offline
post #28 of 31 Old 01-14-2013, 06:43 PM
1 set of camber bolts, new dust boots, and all new spring insulators.
post #29 of 31 Old 01-15-2013, 08:44 AM Thread Starter
Alright, and just one last question.
Is there any specific brad of camber bolt that I should steer towards?
I know you guys probably get tired of all these repetitive questions on here but I appreciate the help.
BoostBum is offline
post #30 of 31 Old 01-15-2013, 09:53 AM
Whiteline, SPC, and Eibach are all fine. It's just a bolt and a nut.
