cobb accessport CEL clearing - Subaru WRX Forum
post #1 of 18 Old 10-22-2011, 01:29 AM Thread Starter
Klone's Avatar
Hi everyone. i have a quick question about the cobb accessport. would i be able to have the accessport keep O2 sensor CEL from popping up permanently? -thanks
Klone is offline
post #2 of 18 Old 10-22-2011, 01:40 AM
Which O2 sensor?
post #3 of 18 Old 10-22-2011, 10:47 AM
rex2002's Avatar
i dont think so. i had a cel after cobb install and cleared it out,but it would always pop back on every few days after i cleared the code
rex2002 is offline
post #4 of 18 Old 10-22-2011, 02:24 PM
If you reflash to a stg. 2 it should, but not on a stg.1
post #5 of 18 Old 10-22-2011, 11:43 PM Thread Starter
Klone's Avatar
O2 sensor
Originally Posted by brfatal View Post
Which O2 sensor?
the one in the downpipe
Klone is offline
post #6 of 18 Old 10-22-2011, 11:44 PM Thread Starter
Klone's Avatar
thanks guys for the info!
Klone is offline
post #7 of 18 Old 10-23-2011, 08:30 AM
You can use a mechanical fix for that. It's a spark plug defouler. You can find them on Ebay for cheap and it works...
post #8 of 18 Old 10-23-2011, 03:50 PM Thread Starter
Klone's Avatar
so it would just be screwed on the O2 sensor and installed in the downpipe?
Klone is offline
post #9 of 18 Old 10-23-2011, 05:46 PM
Yep it's that easy.
post #10 of 18 Old 10-23-2011, 07:53 PM Thread Starter
Klone's Avatar
Yep it's that easy.
nice! would this also work if im not using an accessport?
Klone is offline
post #11 of 18 Old 10-23-2011, 09:08 PM
Should that's how I got around it.
post #12 of 18 Old 10-24-2011, 05:54 AM
Or WITH the AP in ATR, you can check off the codes and then reload the map into the AP and then back into the car.
post #13 of 18 Old 10-24-2011, 06:51 AM
Cobb's stage 2 map disables the rear O2 code. If the light is still on you have a different problem.
post #14 of 18 Old 10-26-2011, 12:27 AM Thread Starter
Klone's Avatar
hmmm, well ill probably end up doing the fouler fix once i get a cattless downpipe since to me its the cheapest way to get more hp and avoid cel. thanks guys for your help!
Klone is offline
post #15 of 18 Old 10-26-2011, 05:11 AM
Actually getting the tune is a better way to get more hp. The DP will do very little to help with horsepower on an untuned car.
