You will probably end up with a CEL. A 2.2KOhm 1/2 watt resistor from radioshack is your cheapest option. just plug it into the EGT connector which is the bottom connector just infront of your passenger side strut tower. I would also reccomend plugging the EGT hole with an M12x1.25 bolt since down the road the EGT probe may become weak and break off into your turbo. The AP will fix the solution too.
well you do have to have stage 2 parts to be able to run that map. The uppipe alone is not reason to run stage 2, you can do stage 1 though.
