Can I run without an O2 Sensor - Subaru WRX Forum
post #1 of 8 Old 08-02-2006, 11:54 PM Thread Starter
So, I just got my invidia V2 DP installed but, taking the O2 sensor out of the oem DP, we found the threads unbelievably stripped. It wasn't possible to put it back into my new DP so i'm running without an O2 sensor right now! Is it ok to run without this? And is it possible to clear the CEL with my AP?
jayj713 is offline
post #2 of 8 Old 08-03-2006, 03:18 AM
Jave's Avatar
The AP should clear any Cat CELs so running without it should be cool. Just be sure to plug the bung with a bolt or something. Alternatly you could try to run a die down the threads to see if it wouldbring them back.
▼SbiΣ Mi▼
Jave is offline
post #3 of 8 Old 08-03-2006, 10:26 AM Thread Starter
So am I supposed to do something so that AP clears the CEL? Cause I did the Reset ECU thing but the CEL just came back on around 20 miles later.
jayj713 is offline
post #4 of 8 Old 08-03-2006, 12:41 PM
nick4592's Avatar
You will need to trick the ECU into thinking the O2 is there
http://www.google.com/search?hl=en&q=WRX+O2+CEL+fix
nick4592 is offline
post #5 of 8 Old 08-03-2006, 01:32 PM
I thought the AP was supposed to delete CEL's, or does that only apply if the o2 sensor is installed and your running a catless downpipe. I never ran my car without a o2 sensor so I'm really not sure.
ScoobyWRX is offline
post #6 of 8 Old 08-03-2006, 01:36 PM
9d2TSi's Avatar
You could try helicoil.
Also, I'll move this for you. It's in the wrong forum.
9d2TSi is offline
post #7 of 8 Old 08-04-2006, 11:24 PM Thread Starter
Ok thanks everyone I guess I do have to have something plugged in to get my AP to clear the CEL. Since my threads are completely stripped on the sensor, do you guys think it will work if i just cut off the sensor part and just plug in the plug? Then i can plug the hole with a bolt or something.
jayj713 is offline
post #8 of 8 Old 08-05-2006, 02:29 PM
9d2TSi's Avatar
You shouldn't run the car without it. If all else fails trying to repair it, get a different downpipe.
9d2TSi is offline
