Old 12-03-2005, 07:02 PM   #46 (permalink)
stileguy's Avatar
Reputation: stileguy is an unknown
the joys of map sensed engine management
Old 12-03-2005, 09:10 PM   #47 (permalink)
Reputation: dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to dumdum is a WRX expert worth listening to
True but it has its limitations as well.As long as you have programable engine management 50% of the intakes are a good design and just need slight recalibration of the MAF signal.
Aarg matey!
ECU Pirated by RomRaider
Old 01-11-2006, 02:55 PM   #48 (permalink)
Reputation: sunchopper is an unknown
Does the CAI have the same problems with the 06 WRX?
Old 01-11-2006, 02:59 PM   #49 (permalink)
Car: 04 WRX
Just by looking at the engine, it looks like the design of the airbox and location of the MAS is still the same, so I'd say yes, still a big no no for the 06 WRX.
RIP Colin McRae
Old 01-11-2006, 03:03 PM   #50 (permalink)
Well I really don't care for a CAI... although I am not sure where to start with modding my car. Seeing as I am a newb I am just gonna read around and learn as much as I can for the time being. I think the reason most people want a CAI is it has an easy install, its not too expensive, and ricers love it. I think every ricer in my school had one... then again, I am a newb and could be wrong. :/
Old 01-23-2006, 06:23 PM   #51 (permalink)
Reputation: balex5884 is an unknown
Originally Posted by dumdum
Just because your car hasn't gotten a CEL yet doesn't mean eveything is just peachy.The best way to tell if the intake is not so hot is to measure the inside diameter with a digital caliper.The magic number is 65mm.If you read back through this post you will see the intake skews the MAF signal.It causes mis readings and lean conditions at w.o.t./full boost.Re-read this thread again.Also checking in some of the other forums FAQ's will maybe help too.Almost evry single WRX forum will have an explanation to this question.
Are any of you familiar with the APS Cold Air intake? They claim that, their intake will work in harmony with the stock engine management, their intake is distinguished with the numerals "65" cast into the inside diameter of the engine hose end. Having that said, do you think i would still be running lean?
Thanks
Old 01-23-2006, 06:53 PM   #52 (permalink)
Thanks
Obviously the "65" designates 65mm.If it is made to work in harmony with the stock ECU then obviously as well this translates they understand the issues had with intakes on WRX's.I personally don't like the fact that its cast because you will not always keep tight tolerances with a cast piece.There will always be some variences from casting.The Perrin,Cobb,and Turbo XS seem a better route to go if you actually NEED an intake.
Old 01-24-2006, 07:28 PM   #53 (permalink)
Thanks, Aps CAI is what i have and in my opinion so far they are the most trusted ones with the most researches.
Check it out http://www.airpowersystems.com.au/us...i/2004_sti.htm
Old 01-24-2006, 07:37 PM   #54 (permalink)
I know about them/it.APS is a very good company with quality products.I have their up-pipe and am very pleased with its construction and engineering.But thats not to say other manufactures don't have products of the same quality and engineering.Cobb's intake by far would be my choice for a short ram and APS definatly for a C.A.I.
Old 02-03-2006, 05:28 PM   #55 (permalink)
eighth08's Avatar
Car: 05 WRX
Club Region: NorCal
Reputation: eighth08 is more helpful than not
Send a message via AIM to eighth08
it's funny, people want to change the intake on subarus sooo bad.. even when told no you dont need it, they still wanna argue it just so they feel better about wanting one.. i know this from experience.. haha. i say ignore the idea of an intake besides the filter and silencer removal.. get exhaust and tuning..and handling mods... money better spent.
Gregory-
keep it in the dirt.
Old 04-27-2006, 07:06 PM   #56 (permalink)
Reputation: buckofbox is an unknown
Send a message via AIM to buckofbox
Is there any reason not to remove the silencer in terms of reliability? Also what's the noise level like? Is it uber loud, or a just a pleasant intake noise?
Old 04-28-2006, 08:52 AM   #57 (permalink)
Everybody has different opinion about what to do for the intake system on the WRX.Some short ram,some C.A.I.,and some modified/stock oem airbox.I personally use the stock airbox,Green drop-in filter,and a 4" velocity stack in the inlet hole.Reliability is no problem unless you don't have the wheel well/inside fender liner The inlet hole is at the same hieght as the inlet scoop.It is alittle bit louder(especially with a high flow filter and TBE).Summit Racing sells a 3" I.D. velocity stack that fits right in the inlet hole.The stock elbow is about 2 3/4" I.D. Open up the hole alittle bit.
Old 06-06-2006, 02:06 PM   #58 (permalink)
Final Clutch's Avatar
Car: 05 WRX
Reputation: Final Clutch is an unknown
Anybody know anything about the SPT Short Ram Intake that is in development?
Old 06-06-2006, 02:09 PM   #59 (permalink)
bradley03's Avatar
Reputation: bradley03 is an unknown
Look for the thread in the Newbie forum titled "So you want an intake" that I posted about it a few days back.
-Brad
05 wrx sti
▼SùbiΣ Mäƒiä▼
Old 10-10-2006, 05:34 PM   #60 (permalink)
Reputation: chrishalos is an unknown
Send a message via AIM to chrishalos
My successful installation in 02 WRX Of Injen CAI - if anyone cares...
My roommate and I installed an Injen CAI on my 2002 WRX recently (maybe a month and a half ago), and I have had zero problems - the CEL came on with initial startup following installation, but turned itself off within 3 minutes and never came on again.
In my opinion (and it is only that), the easiest and most effective way to install the CAI is to jack up the passenger side, remove the tire, and pop off the front half of the fender well (isn't that what they call the thing??). Then pop out the resonator box and proceed with installation steps. Instead of a single pipe design like that of the Perrin (looks that way to me from the picture), Injen uses two pipes connected by a hose joint to make it much easier to install the intake pipe.
I've been driving with this intake for about 4k miles, and have had no problems and no CELs since the initial appearance of it (which, I should clarify, turned off on it's own, so I don't know what the code was).
Hope that helps anyone who is considering the Injen CAI. Happy tuning!
