BOV or Air Fuel Sensor Problem? - Page 2 - Subaru WRX Forum
 6Likes
post #16 of 19 Old 06-26-2014, 07:08 PM
Fidrat's Avatar
Originally Posted by boo-key bear View Post
Your right. The one in the up is egt. I wouldn't put a resistor on the front one. The rear one is the one that causes the cel associated with a tbe. That's the one people use the resistor fix or anti-fouler fix on. Not the Front .
I thought you were talking about the sensor in the uppie. That would be the EGT,the one to use the resistor cel fix on. Not the front o2 sensor. I've never heard of anyone putting a resistor in that one before, for any reason. I don't even know what that would do.
I've also never heard of anyone fixing a cel from the rear o2 sensor with a resistor. Just an anti-fouler fix or a tune can do that as I understand.
Just to be clear...
If the front o2 sensor is bad replace it.
If the rear o2 sensor is bad or throws a cel ,use an anti-fouler fix or replace it.
If the EGT is bad and you still have a cat there replace it.
If not remove it,plug it and do the resistor.
Fidrat is offline
post #17 of 19 Old 06-26-2014, 08:00 PM
boo-key's Avatar
Just to be clear...
Correct. Sorry for the misunderstanding.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #18 of 19 Old 06-26-2014, 10:00 PM
Originally Posted by brfatal View Post
A blow off valve will not affect your idle nor will it cause a CEL. And hope you're not backfiring.
Haha, you're such an ass.
Words taken from you:
Step one: place BOV in hand
Step two: open trash can
Step three: drop BOV in trash can
Step four: take out trash
Problem solved....
Or something like that.. Hahaha
man show and boo-key like this.
post #19 of 19 Old 06-26-2014, 10:47 PM
More or less the correct steps to take.
boo-key, BLAZE2099 and Brockton like this.
