Aem water methanol nozzle size? - Subaru WRX Forum
post #1 of 3 Old 08-23-2016, 01:51 AM Thread Starter
alaskaracetuner's Avatar
alaskaracetuner is an unknown
what size should I pick for my wrx 2016 modded with cobb j pipe non-resonated, cobb air intake, aem charge pipe?
Thank you.
alaskaracetuner is offline
post #2 of 3 Old 08-23-2016, 05:55 AM
titter's Avatar
this is a question for your tuner.
nozzle size is dependant on what you're running in your specific setup.
dont forget to wave
titter is offline
post #3 of 3 Old 08-23-2016, 10:13 AM
arcticscythe's Avatar
Nozzle size is dependent on how much flow you intend to run which is dependent on how much knock protection you need. It should be balanced with your intended boost and your desired performance outcomes.
Your tuner will likely start with the small nozzle and tune from there. Depending on how your system is handling the small nozzle the tuner may stop there of they might go bigger.
- Jason
arcticscythe is offline
