Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Newbie Forum
Old 10-24-2009, 06:42 PM   #1 (permalink)
lancer_013's Avatar
Reputation: lancer_013 is an unknown
how come sum guys subee cherp when shifting
Old 10-24-2009, 06:52 PM   #2 (permalink)
You mean the sound of the BPV (By Pass Valve), or BOV (Blow Off Valve)? This effect can be done several ways. Cheapest, easiest, safest way is to do the "snorkus/snorkel" removal and put a drop in filter in the stock box. You can also change out the stock airbox for either a CAI or SRI. You could also take of the stock BPV and replace with sometype of BOV. This can result in idle issues, rich conditions, and other not so great things for your car. This effect can also happen after upgrading your exhaust and turbo.
Old 10-24-2009, 07:39 PM   #3 (permalink)
lancer_013's Avatar
no the bov it's like there cherping gears hes a video
Old 10-24-2009, 08:30 PM   #4 (permalink)
You mean chirping the tires. If you see in the beginning and the title of the video its because of the horsepower its making. You need a good bit of torque, and a STRONG driveline. Lil Shoaf, he posted somewhere on here a pic of his 4 wheel burn out. But hes making some good power and has his whole driveline is aftermarket.
Old 10-25-2009, 12:14 AM   #5 (permalink)
lancer_013's Avatar
yup look and sound cherry
Old 10-25-2009, 07:53 AM   #6 (permalink)
And cost ALOT of money.
Old 10-25-2009, 01:16 PM   #7 (permalink)
lancer_013's Avatar
how much horsepower you think i would need to make it do that
Old 10-25-2009, 02:35 PM   #8 (permalink)
Probably around the 300 or more power range. But you will also need the transmission, axles and driveline to handle the shock and abuse also.
Old 10-26-2009, 10:50 AM   #9 (permalink)
lancer_013's Avatar
about how much u think it will cost
Old 10-26-2009, 10:57 AM   #10 (permalink)
It cost me around $3800 just to get to my 326 AWHP mark. Im planning a transmission rebuild later in the winter. The gears Im using themselves cost about $3500 just to purchase, plus a stage 3 clutch and flywheel, not sure on the labor yet.
