You missed something...A bank account with a large sum of money in it that you don't mind tossing away.
Holy crap, that's an understatement!
It can be done on a budget, but remember the golden rule when it comes to modifying Subarus: reliable, fast, inexpensive... pick two.
Be prepared to fill your gas tank when it's empty after 200 miles or so too.
To give you an idea of what kind of build you're talking about, check out my mod list. Of course, not all of the mods are completely necessary and there are many different paths you could take to reach your goal.
4 BAR MAP sensor
20% window tint
ACL race main/rod bearings
ACT heavy duty street clutch
ARP head studs
Aeromotive fuel pressure regulator (black)
Albins 1-5 helical gear set
Aluminum dead pedal
Apexcone 35W 5000K HID low beams w/ wiring harness
BC Racing BR coilovers
BC Racing rear camber plates
BC Racing rear coilover adjustment extensions
Chrome/Amber turn signal bulbs (front/rear)
Cobb AccessPORT V2 (speed density tune, 442 whp/357 wtq)
Cobb shift knob (white w/ red band)
Cosworth intake manifold (flipped)
DBA 4000 T-slot front/rear brake rotors
Disabled daytime running lights
Dunlop Direzza ZII summer tires (245/40/17)
Dunlop Winter Sport 3D winter tires (205/50/17)
Fragola fuel pressure gauge (black)
FuMoto engine oil quick drain valve
Garrett GTX3076 .82 turbo (rotated)
Goodridge stainless steel brake lines
GP Moto intake silencer delete elbow
Grillcraft 3 piece upper grill kit (black)
GrimmSpeed 3 port EBCS
GrimmSpeed 8 mm phenolic spacers
Group N engine mounts
GT Spec UEL V-band header
Hawk HPS brake pads
Hella high beam bulbs (yellow)
Hella Supertone horns (red)
HKS Hi-Power Carbon-Ti cat back
IAG air/oil separator (black)
IAG air pump block off plates
IAG big core FMIC
IAG battery tie down (black)
IAG brake fluid reservoir cap (black)
IAG clutch fluid reservoir cap (black)
IAG engine oil cap (black)
IAG engine oil dipstick (black)
IAG half moon valve cover cam seals
IAG radiator stays (black)
IAG speed density air intake w/ K&N cone filter
IAG Stage V head package (ported/polished)
IAG TGV deletes (black)
IAG top feed fuel rails (black)
IAG V-band 3" downpipe
IAG V-band external wastegate dump tube
IAG V-band up pipe
IAG windshield washer fluid reservoir cap (black)
Injector Dynamics 1,000 cc injectors
Kartboy engine pitch stop mount
Kartboy front/rear polyurethane shifter bushings
Kartboy rear differential/crossmember bushings (black/race)
Kartboy rear endlinks
Kartboy short throw shift lever
Kartboy transmission crossmember bushings
Kelford 264 cams
Killer B ultimate oil pickup
Koyo polished aluminum racing radiator
Lamin-X fog light covers (yellow)
LED front parking lights (cool white)
Lotek triple A-pillar gauge pod (light grey)
Manley exhaust valves (33 mm)
Manley H-beam rods
Manley intake valves (37 mm)
Manley Platinum Series pistons (99.50 mm)
Manley valve springs/retainers
McGard spline drive lug nuts
Mishimoto brake fluid reservoir (chrome)
Mishimoto coolant overflow reservoir (chrome)
NGK one step colder spark plugs
Nitrided crankshaft
OEM armrest extension
OEM dark gray WRX carpeted floor mats
OEM tail lights (04/05 w/ JDM bulb rearrangement)
OEM trunk cargo net
Painted headlight housings (black)
Painted stock wheels (black)
Perrin lightweight crank pulley (black)
Perrin stout mounts (black)
Prosport 52 mm Premium electric boost gauge (green/white)
Prosport 52 mm Premium exhaust gas temperature gauge (green/white)
Prosport 52 mm Premium oil pressure gauge (green/white)
Prosport carbon fiber hood damper kit
Prosport turbo blanket (black)
Rally Armor mud flaps (red w/ white logo)
Rolled/pulled front/rear fenders
Rota DPT 17x9 +42 wheels (gold) w/ hub centering rings
Samco silicone radiator hoses (black) w/ T-bolt clamps
Seibon carbon fiber trunk w/ Mine's replica spoiler molded (painted OBP)
Smoked acrylic rear window/roof spoiler
SPT transmission mount
STi 11 mm engine oil pump
STi V-Limited replica front lip
Subtle solutions radiator shroud (black)
TiAL 44 mm external wastegate (black)
TiAL Q 50 mm blow off valve (black)
Vanity front/rear license plates "SPINS 4"
Walbro 255 LPH fuel pump
WeatherTech DigitalFit floor liners (black)
Whiteline 22 mm adjustable front sway bar
Whiteline 24 mm adjustable rear sway bar
Whiteline rear subframe lock bolts
Yakima roof rack (44 mm fairing, round cross bars cut flush, FatCat 6 snowboard carrier, and SKS locks)
