at 17 psi how much is safe - Subaru WRX Forum
post #1 of 11 Old 02-08-2007, 09:22 PM Thread Starter
02wrxjade's Avatar
02wrxjade is an unknown
I have an 02 wrx with the following mods i am currently running a lil above 17 psi and was thinking about playing with the manual boost controller but dont want to risk it without asking people that know what there doing first
Engine:
aluminum-polished intake
HKS down pipe
HKS cat delete pipe
HKS SSQ blow off valve
TurboXS HP boost controller
TurboXS front mount intercooler
Perrin Oil catch tank and Radiator over flow tank
machined and tig welded power steering reservoir
all hoses are Samco silicone 3 ply
TurboXS utec with Remote Map selector
Underdrive Pulley
Suspension:
JIC FLT-A2 coilovers with JIC control arms
Cusco Front Tower Brace & Sub frame brace
02wrxjade is offline
post #2 of 11 Old 02-08-2007, 09:26 PM
ilovecake's Avatar
ilovecake is an unknown
Send a message via AIM to ilovecake Send a message via MSN to ilovecake Send a message via Yahoo to ilovecake
Boost controller, I would say is no good and you should sell it. Our cars do NOT like those and you will destroy your engine eventually with one. Sorry.
Save the environment or ill f***ing kill you!
ilovecake is offline
post #3 of 11 Old 02-08-2007, 09:46 PM
JOHNYCAMP's Avatar
JOHNYCAMP is an unknown
the problem with the maual boost control on your set up is that , you never know how much your car is going to react to the slightest adjustment of the boost controller. you might turn it a 1/4 turn and get a 3 psi reaction. if that happens , say goodbye to your engine.
I say , if you have a maf sensor in a subaru , don't mess with manual boost controllers unless you are a tuner , have a tuner that checks your tune after every fill up, or have a lot of cash to repair your car.
Besides, just turning up the boost on your car with those mods will probably make you slower, the ecu will compensate by retarding the timing.
JOHNYCAMP is offline
post #4 of 11 Old 02-09-2007, 01:42 AM
get a protune man.
i like the green avatar is that your car?
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #5 of 11 Old 02-09-2007, 02:40 AM Thread Starter
02wrxjade's Avatar
yea thats my car theres a bunch of picture on car domain http://www.cardomain.com/ride/2544743 if you want to check it out i have not had time to put them up on here thanks for the advise guys i will just keep it as it is, runs great now no need to #### with it
post #6 of 11 Old 02-09-2007, 06:27 AM
03'WRXDriva is an unknown
Send a message via MSN to 03'WRXDriva Send a message via Yahoo to 03'WRXDriva
Seen that on ebay a while back i think it was posted here you must be the "lucky" winner of the bid?
03'WRXDriva is offline
post #7 of 11 Old 02-09-2007, 06:34 PM
it definatly stands out. most people would say its ricer but i like it, probably the only aftermarket paint that i do like. its not an annoying color combo the two greens go together really nice.
i am gonna give you a !Thumbs Down on the interior though IMO
call me a ricer but on your car.
Robby
02 rex is gone.
Evo is gone :(
Now I got nothing.
post #8 of 11 Old 02-11-2007, 11:56 PM
I'm confused. Why would you use a boost control if you have a UTEC? As long as you have the correct map/tune, you should be fine. You can use UTEC's ABC to control the boost. Stick to 17psi. Stock turbo maxes out around there, and your injectors aren't too far from it either.
post #9 of 11 Old 02-12-2007, 06:50 AM
I concur with the injectors maxing out but not the turbo.There is a td04-13T compressor map i have a link to somewhere on this forum.I run 20psi in the midrange and some up to 22psi with supporting fuel and I.C. Tapers very quickly to 15psi by 6500rpm.Its pushing things alittle but i have worked my way up slowly and have 100K on the motor so its had a good life! But you need to be tuned for it.If you can access your map i doubt the fuel and timing are scaled for to much higher a load.
dumdum is offline
post #10 of 11 Old 02-12-2007, 08:09 PM
General consensus is that over 17psi, you turbo starts to blow air too hot to be effective. But, I suppose if you had time to play with it, you could make it work. Most people don't have that patience or desire to max out the TD04, unless they're doing sanctioned racing with certain rules.
post #11 of 11 Old 02-13-2007, 06:43 AM
That was just speculation because no one had a compressor map for the 13T.Hell for a while everyone thought the WRX had a 13G.http://forums.nasioc.com/forums/show...compressor+map
dumdum is offline
