'02 wrx sputters after open source tune... help - Subaru WRX Forum
 3Likes
  • 1 Post By Nathan21
  • 1 Post By sleepr
  • 1 Post By BLAZE2099
post #1 of 11 Old 11-20-2013, 03:02 PM Thread Starter
staiflexat1 is an unknown
'02 WRX tuned with OPENSOURCE
I have a first gen HKS blow off valve... it does not recirculate...
When I hit the gas before the blow off valve opens the car sputters, when I drive it and shift gears and hit the gas again it sputters again...
I think it's running too rich or too lean...
The shop said that the blow off valve sping is weak so there is no way tuning around that...
They suggested the turbosmart compact blow off valve that is recirculating and that should take care of the problem...
Also need to install a GrimSpeed boost solenoid so it can hold boost to red line and not fall off...
Is there a way the tuner can tune the tip in throttle? can they also tune surging?
They will have to tune it again once the boost solenoid is there, I just want to make sure these guys know what they are doing?
I would really appreciate some input...
If anyone had this problem... how did it get fixed?
staiflexat1 is offline
post #2 of 11 Old 11-20-2013, 03:18 PM
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
Get a bpv and your answers will be solved
get something that is FULL Recirculating
Haw1es likes this.
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #3 of 11 Old 11-20-2013, 03:50 PM
Brockton's Avatar
^This
Brockton is offline
post #4 of 11 Old 11-20-2013, 04:10 PM
thekamikaze kid's Avatar
I just had this. I had a hks bov, what u got is what I believe compressor surge. Is it makin a flutter sound? If so a new bpv/bov should fix this. I'm not sure but u might be able to fix the one u got by tightening it er something. everyone here will tell u to go back to stock, will defiantly fix this prob, but no sound. Good luck.
thekamikaze kid is offline
post #5 of 11 Old 11-20-2013, 06:26 PM
Who is your tuner?
post #6 of 11 Old 11-20-2013, 06:34 PM
sleepr's Avatar
Images: 13
Heed your shop's suggestions. They are telling you what is needed in order for them to properly tune your car.
If they weren't legally obligated to allow you to make the decision, they would have already made those changes before they attempted to tune your car.
turmic likes this.
Matt
Stroked and stoked!
sleepr is offline
post #7 of 11 Old 11-20-2013, 08:06 PM Thread Starter
would a 50/50 blow off valve work? or do I need to get a 100 % recirculating blow off valve?
I really like the blow off valve sound.
Does anyone have a good Recirculating into the atmosphere blow off valve that would work well?
post #8 of 11 Old 11-20-2013, 08:29 PM
post #9 of 11 Old 11-20-2013, 09:21 PM
We advise against them
Originally Posted by thekamikaze kid View Post
Really.
Sheesh
turmic likes this.
post #10 of 11 Old 11-21-2013, 10:14 AM
Look at a Forge BPV then.
post #11 of 11 Old 11-21-2013, 10:25 AM
Cobb's XLE bpv might also be an option.
