V8 Spec C EJ207 swap to 4EAT - Page 2 - Subaru WRX Forum
 31Likes
post #16 of 100 Old 01-07-2016, 09:25 AM Thread Starter
titter's Avatar
thanks man! these are things i like to know any known cause? is it too much heat or something?
the jdm spec c inlet is already bigger than normal. the internal diameter is the same as most silicon inlets with 2.4" turbo connection. i really dont want to have to do my turbo inlet untill i upgrade the turbo a ways down the road as i will be going 3".
dont forget to wave
titter is offline
post #17 of 100 Old 01-07-2016, 09:48 AM
GSMNZ's Avatar
Yes I believe my tuner pointed the issue to the heat causing it to shrink over time. Again I know Perrin makes quality products. I have their BigMAF Intake on my last set-up and it was great. But the Perrin Inlet not so much.
titter likes this.
GSMNZ is offline
post #18 of 100 Old 01-09-2016, 04:17 PM Thread Starter
titter's Avatar
thats a wrap folks!
http://forums.nasioc.com/forums/show....php?t=2298336
Thermotec Turbo Wrap Kit http://www.thermotec.com/products/15...ating-kit.html
dont forget to wave
titter is offline
post #19 of 100 Old 01-11-2016, 03:33 PM Thread Starter
titter's Avatar
here is an OEM timing belt kit we pieced together for the EJ207 (typed for clarity)
1) Tensioner - 13033AA042
2) Timing Belt - 13028AA240
3) Small Idler - 13073AA230
4) Toothed Idler - 13085AA080
the other 2 dont have normal subaru stickers or part #'s but the box says PU306030FRR9H above the barcode. both are identical and from the dealership. these are all parts i purchased.
new fluid & filter also going in the trans as well
proper drain and drop method. do not power flush a 14 yr old 4EAT. you will explode the insides.
dont forget to wave
titter is offline
post #20 of 100 Old 01-14-2016, 02:36 PM
I have always used gates timing belt kits for mine.
GSMNZ and titter like this.
post #21 of 100 Old 01-15-2016, 07:42 AM Thread Starter
titter's Avatar
yea heard plenty good things about the gates kit. but with the canadian dollar so low, ordering one was only going to be $20 less than that oem parts lol
what gates kit do you use?
dont forget to wave
titter is offline
post #22 of 100 Old 01-22-2016, 02:42 PM Thread Starter
titter's Avatar
so i found some water in my rear footwell and wondered why because noones ever in my back seat. things got a little out of hand lol trying to solve the problem...
and then i found the problem...
welcome to the canadian rust belt. thats the passenger side. drivers side is twice as bad.
Replacement Panels. Might as well go all out. no sense half-assing anything now.
if anyone is looking for panels since this is a common problem
going to get coated inside and out with Por15
RoboTuner likes this.
dont forget to wave
titter is offline
post #23 of 100 Old 02-02-2016, 05:39 PM Thread Starter
titter's Avatar
lets get away from this depressing rust.... back to the good stuff. almost all my parts have arrived!!
Prosport EVO Boost, Wideband & Oil Pressure
JDM STI Solid Steering Link, Whiteline Steering Rack Bushings, TiC Diff Bushings, Kartboy Rear Outrigger Bushings & Subframe Lockdown Bolts
STI Group N Motor Mounts, Grimmspeed 3 Port EBCS, Perrin Pitch Stop Mount
things still to come: walbro255 fuel pump, ngk colder spark plugs, and lachute twin scroll turboback
dont forget to wave
titter is offline
post #24 of 100 Old 02-04-2016, 05:38 PM
the #### is a twin scroll turboback?
post #25 of 100 Old 02-04-2016, 07:57 PM Thread Starter
titter's Avatar
exhaust sorry lol
dont forget to wave
titter is offline
post #26 of 100 Old 02-10-2016, 09:50 AM Thread Starter
titter's Avatar
lol
really though... gotta stop all this power or a wall/tree will do it for me lol. and i'll still be able to use my winter 16"s smoking deal. came with pads/rotors AND the kartboy bracket.
dont forget to wave
titter is offline
post #27 of 100 Old 02-12-2016, 03:14 PM Thread Starter
titter's Avatar
New Pads, Rotors, & Lines for the 4/2 pots
dont forget to wave
titter is offline
post #28 of 100 Old 02-12-2016, 03:24 PM Thread Starter
titter's Avatar
BEFORE
AFTER
just need to find some cherry blossom red to touch up the STI. grimmspeed sells it but its like $40 a can
dont forget to wave
titter is offline
post #29 of 100 Old 02-14-2016, 08:07 PM Thread Starter
titter's Avatar
Lachute Twin Scroll Cat-Less 3" Turbo Back Exhaust
they use high end magnaflow muffler and resonator. both straight through design.
all wrapped up ready for installation. one full 50' roll 1" wide of DEI Titanium wrap
welds on this entire product are beautiful. this is definitely a well made product. comes with the bung needed for the front O2 sensor as well as a wide-band bung. also has the 3rd mini-cat fix for the rear O2 sensor. they think of everything.
dont forget to wave
titter is offline
post #30 of 100 Old 02-15-2016, 09:26 AM
RoboTuner is a helpful contributing member
Magnaflow has been proven to allow the most flow at WOT as well as being saddle when you don't want it to be loud. Good looks and I'm waiting for videos!
titter likes this.
RoboTuner is offline
