"Loxxy" Budget Built 08 WRX [unique/custom fabrication] - Subaru WRX Forum
 3Likes
post #1 of 20 Old 12-02-2016, 05:14 PM Thread Starter
Ruso's Avatar
Hello Everyone.
I guess since I requested this feature, I'll be the first to start a built post.
I'm not rich, buying a WRX has always been a dream of mine and I finally justified getting one because I live in severe snow area and get completely snowed in in the winter and have to snowmobile to my home. Also, I noticed something about other builds: it seems like a lot of people either follow the same paths and all the cars look very similar with almost identical build configurations... or they go completely custom. I've spent several years working at an Engineering company and have picked up some useful tools. I'm also an artist and in the process of building my art career so it's important for me to have things that are functional but also beautiful.
I started with a bone stock World Rally Blue wrx with 76k which I grabbed for just over 17k.
Build goals:
-Quality but affordable
-Daily commuter
-As much as reasonably possible custom fabrication (I don't have the skills or tools to fabricate a quality exhaust for example)
-Unique/Different than other builds
-Geared for a lot of off-road use as well as tarmac
-No shop, this is a true (gravel) shade tree build
Current Modifications (in order):
Chapter 1 -- First Winter
-Snow tires/rims
-Ram Air Intake
-Taxtrix Cable
-Stage 1 Tune
-COBB EBCS
-Learning how to tune to get boost back under control
At this point winter came and I got snowed in. No more mods for a while
Chapter 2 -- After the snow melted
-CNT Quad Tip Catback conversion (I started with a single tip)
-Rev9 Catted Downpipe
-Stage 2 Tune [Custom]
-Blacked out (tail lights, chrome accents, hood scoop, side skirts, rims)
I was actually very happy with this setup for most of the summer but really wanted to upgrade the turbo. After crunching numbers and doing research I realized that it would be much cheaper for me to get a used VF39 and fabricate a custom Water to Air Intercooler setup rather than going VF52 with a TMIC or FMIC setup. This is where things got serious with the build.
Chapter 3 - VF39, Custom Water to Air Intercooler
This section has a full writeup. You can find it here: Turbo Upgrade and Fabrication on the WRX ? Dmitri's Gallery
-Custom Water to Air Intercooler setup fabricated
-VF39 installed
-Improved Custom RAM Intake with Cold Air box
-Custom tuned for this setup by merging several maps together and tuning boost
-Blacked out headlights and built custom halos.
To be continued......
Vew likes this.
Ruso is offline
post #2 of 20 Old 12-02-2016, 05:15 PM Thread Starter
Ruso's Avatar
At this point I was very happy. The car really likes the WAIC setup and the new turbo. I was just under 300whp (never confirmed on a real dyno, but I did on a "road dyno" in RomRaider).
The new turbo spools up as quick as the TD-04 did (within 100 rpms) since there is no restriction in the intake path with the new HUGE Water to Air unit. I also gutted my originally catted downpipe so there was no restriction there either. The car was now loud, made loud pops and bangs during shifting and spit fire.
The big downfall with such an unrestricted setup is that my boost was wild and all over the place. My wastegate was no longer able to keep up and I had to settle for either a boost spike, or tuned down boost... I could only live with it for so long until I went EWG.
Chapter 4 - Roar, Rumble, Pop, Gurgle, Scream.... Carnage....
-Used a RomRaider hack to build a free Anti-Lag System.
-Through the hood EWG setup.
-Tuned again for EWG
As if my car wasn't ridiculous enough... and since I needed to go External on the Wastegate, I decided to go full blown immature on this one... but it gave me a chance to do some interesting fabrication.
I'm still trying to decide whether this mod may have been a little too much or not. . It's bloody loud at WOT... quite a bit louder than I expected. But, I do like it .
At this point I was very happy with the power levels and decided that I was finished with power modifications. However it may have been a little late because the extra bump in power from the EWG coupled with what I now know as a tune that would slightly lean the car out while driving over a mountain pass... the worst possible thing happened. I reached the limits of my car and horrendously blew my motor.
The motor had a HUGE hole in the top. I spilled all of my fluids ALL over the bottom side of the car.
I decided it was time for a full rebuild and a new built short block.
I went with an IAG Stage 2 Short Block. Unfortunately this set me back $3k for the short block... 6 weeks of work, and another $1k+ for parts to put it back together.
Gladly I managed to salvage and rebuild the heads myself to save money. They were covered in pieces of aluminum and would not seal, so I had disassemble, replace valve stem seals, clean the heads and all moving parts, lap all the valves by hand, and put them together. They good a clean bill of health from the machine shop and a fresh mating surface.
Ruso is offline
post #3 of 20 Old 12-02-2016, 05:16 PM Thread Starter
Ruso's Avatar
Chapter 4 - The complete rebuild
Last couple months have been very difficult. I'm financially in shambles and have been incredibly stressed rebuilding the car before the snow hit.
But... I kept my head high and used this opportunity to make a beautiful motor, do a few removals of stuff I no longer needed and finish some stuff I half-assed before.
I should note, since I don't have a shop, I literally got to build a complete motor in my living room.. which was actually very nice. I enjoyed it much better than all the previous mods I had to do outside.
-IAG Stage 2 Short Block
-TGV Delete
-Secondary Air Pump Delete
-Engine Paint
-Dual Oil Catch-Cans
-Redid layout/replaced for most vac lines to open up room in the engine bay and remove useless stuff
-Engine Paint
-Engine Install
-Break In
-Tune
I decided to spend some time and painted all the plastic stuff. The paint is a silver metalic base and layers of gold/silver splatter with gradient candy blue tint.
I did TGV deletes and fabricated plates to block off the Secondary Air Pump ports on the heads:
And spent 6.5 days straight (Wake up, eat, build, eat, build, eat, snack build sleep) building the motor.
I made a critical mistake in installing on of the head gaskets backwards, so during first start-up dumped all my oil *doh* and had to pull the motor and do half of it again.
But... in the end she is back together and runs great!
Ruso is offline
post #4 of 20 Old 12-02-2016, 06:01 PM Thread Starter
Ruso's Avatar
I recorded a timelapse video of the motor build. I finally got around to editing it and uploading to youtube.
Ruso is offline
post #5 of 20 Old 12-04-2016, 01:29 PM
0oknm
Guest
Posts: n/a
Hey Ruso
AWESOME BUILD! I have an 08 as well and it's pretty rare to find anyone Willing to put in the time and money for the narrow body's. Well done she looks like a true beast.
How difficult was it to do the external waste gate setup through the hood? That's something I definitely want on my build.
Sent from my XT1585 using Tapatalk
post #6 of 20 Old 12-04-2016, 06:12 PM Thread Starter
Ruso's Avatar
Thanks man. Much appreciated!
The ewg was a bit of a pain, at least the way I did it. I actually modified the stock up pipe and plumbed a pipe up. The clearance between up pipe and frame i and stuff higher up is pretty tight. But, it's doable, and somewhat entertaining if you can weld.
It was the hardest to tighten the bolts on the lower flange, if I did it again, I would put the flange much higher.
If you ever choose to do this, let me know, I can machine the aluminum bezzel that finishes off the hole in the hood.
I've grown to really love my narrowbody. Everyone has the same widebody with the same mods. I like being different, in a quality way if you will.
Ruso is offline
post #7 of 20 Old 12-28-2016, 05:37 AM
titter's Avatar
i think i asked you this on nasioc but i cant find the post.
what AWIC setup are you running? thats the garrett 1000hp core? still debating a grimmspeed TMIC or converting to an AWIC. FMIC is out of the question.
dont forget to wave
titter is offline
post #8 of 20 Old 12-28-2016, 11:27 AM Thread Starter
Ruso's Avatar
Hey titter,
That is not a Garett core. It's a cheap and huge core I got on eBay. I chopped the original inlet and outlet, closed off, and customized to fit the turbo/tb layout on my car.
The parts for the whole system were below $250 including core, heat exchanger, pump and my ghetto fabulous reservoir.
Take a look at my WAIC build here. I've linked to the items I used.
http://dmitris.gallery/2016/07/25/tu...on-on-the-wrx/
Keep in mind there are tons of cheap heat exchangers with different layouts that would work better with different year cars with the other manifold layouts.
Ruso is offline
post #9 of 20 Old 12-29-2016, 05:39 AM
titter's Avatar
nice. do you have any data of its efficiency? like inlet & outlet temps?
your setup looks good. nice short charge path. thats what im after.
dont forget to wave
titter is offline
post #10 of 20 Old 12-29-2016, 05:25 PM Thread Starter
Ruso's Avatar
Hey titter,
I do not have any data. I have not yet tapped for temperature sensors but I will in spring time when I start moving toward Speed Density tuning.
What I can tell you is this: The unit and water has NEVER gotten warm at all even from aggressive driving. Also I am currently trying to see what my VF39 will do and I noticed there's no difference in knocking between 18psi and 23+psi (mind you this is at 2500 elevation and I have elevation compensation on boost disabled) which tells me the system is keeping up with cooling the charge. I also noticed the car didn't mind adding some extra fuel. It used to go into 10s on afr but now I'm in mid 11s and I also did not notice any new knocking (my car NEVER has any fine learning knock... and feedback is rare, and mostly caused by drastic throttle position changing rather than trying to make power at WOT). By all means the car should not be liking this and I will probably not run it like this, but I want to feel around to see how it does because I do want to plop a bigger turbo in next year too.
I'm definitely with you. I really like the concept of having a short intake path. It certainly helps keep my VF39 from over-working itself since it doesn't have to inflate 12ft of 2.5" tubing or something ridiculous like that.
I don't care what people say about FMIC and how there's no delay in spooling.... it's still more than 55 cubic feet of air no matter how you look at it... that the turbo has to pump up every time before the full pressure gets to the manifold... the turbo has to work harder at first to fill that space which creates more heat.
Anyway... I'm trying to log a road dyno run to see what my power figures are looking like but there's just too much snow. The winter has definitely begun.
Ruso is offline
post #11 of 20 Old 01-03-2017, 09:03 AM
titter's Avatar
so i think this is the same heat exchanger: Air to Water Radiator
even has the same drain fitting looks like. which i agree, i cant see needing a drain fitting when u can pop the hose off thats right next to where the fitting is.
i have read alot of positive feedback from the frozen boost products. particularly the Type 14: Water to Air Intercoolers
really interested in your temperature data when you get around to it probably will be going with a very similar setup.
dont forget to wave
titter is offline
post #12 of 20 Old 01-04-2017, 02:14 AM Thread Starter
Ruso's Avatar
Dude, that heat exchanger looks IDENTICAL.... except nearly double the price....
That Intercooler unit looks IDENTICAL construction too.... and also nearly double the price.... (although it's looking like prices are a little bit higher right now than when I built it)
Best of luck! Looking forward to seeing your build on this!
Ruso is offline
post #13 of 20 Old 01-05-2017, 06:08 AM
titter's Avatar
im thinking they all come from the same place. i traced it back to something called "SHAMAN EQUIPMENT". also i think yer core is this one (Type 15) Water to Air Intercoolers
that name ring any bells? maybe somehwere on the sales receipt or the shipping box?
im now trying to find a direct dealer for Shaman Equipment... if thats even possible lol.
also nothing immature about your exhaust lol. if that was legal where i live i would do the exact same thing 100%
actually thats a lie, i would have both EWG and Dump going out my hood lol
dont forget to wave
titter is offline
post #14 of 20 Old 01-05-2017, 09:02 PM Thread Starter
Ruso's Avatar
Lol. Who said it was legal here? ?
titter likes this.
Ruso is offline
post #15 of 20 Old 02-09-2017, 01:36 AM
sleepertc's Avatar
Wow Ruso, man cool stuff!
We live in the same state!
Just found your YouTube vids. Took me long enough I just haven't been on this forum much in a while! I hope everything is going smooth with that new motor! I would love to see it, I bet it's amazing
Sent from my iPhone using Tapatalk
sleepertc is offline
