Scosche HD Amplifiers - Subaru WRX Forum
post #1 of 2 Old 09-17-2012, 03:17 PM Thread Starter
If you're in the market to boost your audio system, check out Scosche HD amplifiers.
Scosche HD is designed for value without compromising sound quality or components. The HD amplifier line-up includes 2 amps. The 2-channel 400 watt amplifier (#HDA4002) boasts a 50 watts RMS x2 at 4 Ohms power output. The 4-channel 800 watt amplifier (#HDA8004) has 50 watts RMS x 4 at 4 Ohms power.
Features
-Thermal overload protection
-Sturdy Aluminum Side Panels
-RCA and high level inputs
-Brushed Aluminum Heatsink and Top Plate
-Dynamic bass boost
Visit the following links for more information on Scosche HD amplifiers:
HDA4002 - 400 Watts Max 2-Channel Amplifier
HDA8004 - 800 Watts Max 4-Channel Amplifier
ScoscheCarAudio is offline
post #2 of 2 Old 02-03-2013, 06:35 PM Thread Starter
Arriving Spring 2013!
Scosche HD 5-Channel Amp & HD Mono Amp
The two new HD amplifiers both feature Class-D topology, thermal overload and short circuit protection, variable crossovers, MOSFET switching power supplies, RCA and speaker level inputs, brushed aluminum heatsink and top plate and dynamic bass boost. In addition, the 5-channel amp and MONO amp have a bass knob included.
The new 5-channel amplifier (#HDA5CHANNEL) is the first all-digital amplifier under $300.00. It’s full-range channels boast 50 watts RMS x4 at 4 Ohms while the subwoofer channel outputs 250 watts RMS at 2ohms for full system power. It also features a separate front and rear input summing, remote bass control port, and selectable gain range.
The 500 watt mono block (#HDA1001) outputs 500 watts RMS x 1 at 2 Ohms and is a full-featured mono amp for under $200.00. It features a power protect indicator, speaker level input and remote bass control port.
Both amps will be available for purchase by Spring of 2013.
