-   Scosche Industries (http://www.wrxtuners.com/forums/f165/)
-   -   Scosche HD Amplifiers (http://www.wrxtuners.com/forums/f165/scosche-hd-amplifiers-33025/)
ScoscheCarAudio 09-17-2012 03:17 PM
1 Attachment(s)
[B]If you're in the market to boost your audio system, check out Scosche HD amplifiers. [/B]
Scosche HD is designed for value without compromising sound quality or components. The HD amplifier line-up includes 2 amps. The 2-channel 400 watt amplifier (#HDA4002) boasts a 50 watts RMS x2 at 4 Ohms power output. The 4-channel 800 watt amplifier (#HDA8004) has 50 watts RMS x 4 at 4 Ohms power.
[U]Features[/U]
-Thermal overload protection
-Sturdy Aluminum Side Panels
-RCA and high level inputs
-Brushed Aluminum Heatsink and Top Plate
-Dynamic bass boost
Visit the following links for more information on Scosche HD amplifiers:
[url=http://bit.ly/Ohnp7y]HDA4002 - 400 Watts Max 2-Channel Amplifier[/url]
[url=http://bit.ly/SF1grx]HDA8004 - 800 Watts Max 4-Channel Amplifier[/url]
ScoscheCarAudio 02-03-2013 06:35 PM
[CENTER][B][SIZE="4"]Arriving Spring 2013![/SIZE]
[IMG]http://i1324.photobucket.com/albums/u602/sandi_msc/SCOSCHE_HD_zps519bfb88.jpg[/IMG]
Scosche HD 5-Channel Amp & HD Mono Amp[/B][/CENTER]
The two new HD amplifiers both feature Class-D topology, thermal overload and short circuit protection, variable crossovers, MOSFET switching power supplies, RCA and speaker level inputs, brushed aluminum heatsink and top plate and dynamic bass boost. In addition, the 5-channel amp and MONO amp have a bass knob included.
The new 5-channel amplifier (#HDA5CHANNEL) is the first all-digital amplifier under $300.00. It’s full-range channels boast 50 watts RMS x4 at 4 Ohms while the subwoofer channel outputs 250 watts RMS at 2ohms for full system power. It also features a separate front and rear input summing, remote bass control port, and selectable gain range.
The 500 watt mono block (#HDA1001) outputs 500 watts RMS x 1 at 2 Ohms and is a full-featured mono amp for under $200.00. It features a power protect indicator, speaker level input and remote bass control port.
Both amps will be available for purchase by Spring of 2013.
