Winter wheels for '11 - Subaru WRX Forum
post #1 of 21 Old 11-29-2011, 05:23 PM Thread Starter
thesaltyguy is an unknown
Im lookin at puttin some winter tires on my '11 wrx this winter, i wanna run 16" wheels instead of my stock 17's..will they fit?....will they fit over my brakes and run fine?...id like a little more meat between the wheel and bumps this winter
thesaltyguy is offline
post #2 of 21 Old 11-29-2011, 05:29 PM
cwinterbower is more helpful than not
My brother just bought some "steelies" with winter tires for his 11 off of a Legacy and said they fit fine, sorta tight for an OEM fit, but nothing to worry about.
cwinterbower is offline
post #3 of 21 Old 11-30-2011, 12:36 PM
16" wheels will clear your brakes. There are even some 15" options, but you have to buy very specific wheels if you want 15".
post #4 of 21 Old 12-01-2011, 03:35 PM
WRXtuners Supporting Vendor
DiscountTire's Avatar
DiscountTire is an unknown
Here is the link with all the the 16 inch wheels we have to fit the 2011 WRX.
Wheel Products - Discount Tire Direct
The Momo Winter Pro S would be an excellent choice.
Let us know if we can be of assistance.
Low Prices! More Choices! FREE Shipping!
DiscountTire is offline
post #5 of 21 Old 12-10-2011, 02:35 PM Thread Starter
yea i have been lookin around the past week and everyone i have talked to, tire warehouse, and few local tire place say 16" wont fit, or it be too tight. But i got on tirerack.com and they say 16" will fit.....think im gonna go there, plus they r alot cheaper than the local guys here in vermont
post #6 of 21 Old 12-12-2011, 12:29 AM
tire warehouse and a few local shops are complete idiots. Again, 15" wheels will clear your brakes let alone 16". FFS, I am not lieing or making shit up. Go look up pictures of your car with 16" wheels, they're everywhere. Your car has stock 17" wheels so your local morons don't want to have to THINK for a living and are sure that 17" will clear. That's all it means. You should look up the 02-05 WRX, used almost identical brakes to the ones on your car and came stock with 16" wheels. In fact, the stock wheels from an 02-05 WRX will fit on your car just fine. The 06-07 WRX had larger brakes than your car and they STILL fit several different 16" designs. Not to be technical, but you can even fit some custom 16x8.5" brakes over STi BREMBOS! The idea that your stock brakes are too big for 16" wheels is absurd.
post #7 of 21 Old 12-12-2011, 08:40 PM Thread Starter
yea meatheads...u got that right...i ended up goin w 16" steels on 215/50....got them alot cheaper online compared to locally. Should be here next week....alll we need is just some snow here now
post #8 of 21 Old 12-21-2011, 01:35 PM
swrt83 is an unknown
I have some 215/50/17s that need wheels but the guys from tirerack think they wont work on a 17" wheel because of the sidewall height. Anyone running this setup?
swrt83 is offline
post #9 of 21 Old 12-21-2011, 02:36 PM
That's the stock height for an 09+ WRX. They work fine on any 09+ WRX. They will work fine on other year WRX's if the suspension is stock and in good working order, they're only slightly taller than the stock 02-05 WRX height. Lots of guys use 215/50R17 for the winter, that's a very normal size people buy on purpose for Impreza's who subscribe to the "lengthen gear ratios for winter" religion.
post #10 of 21 Old 12-21-2011, 05:17 PM
mazzanic's Avatar
mazzanic is an unknown
So 215s will work on my 09?? I was considering it because its 20$ per tire less than 225s.
mazzanic is offline
post #11 of 21 Old 12-22-2011, 10:13 AM
I know lots of guys run the 215/50/17 setup but they're typically on a used 08-09 wrx stock wheel which is 17x7 +53
My concern was rubbing on a 17x7 +45 enkei wheel. Is that offset enough to cause issues?
swrt83 is offline
post #12 of 21 Old 12-22-2011, 10:18 AM
Not all 215's. 215/50R17? Yes, totally fine.
Zero issues with those wheels on a 2011. More offset would help your steering response, but there's no clearance issues with 17x7 +45 on any year WRX let alone the wider fenders of the 09+. Not even close to your fenders.
post #13 of 21 Old 12-22-2011, 10:45 AM
mazzanic's Avatar
^^ good look. Gonna order winterforces tonight
mazzanic is offline
post #14 of 21 Old 12-22-2011, 11:06 AM
I'm assuming you're talking about non sti, right? If so then I'll be gettin that fo sho!
swrt83 is offline
post #15 of 21 Old 12-22-2011, 12:41 PM
I thought you wanted 16" wheels? Wasn't that the point of this thread?
