Wheel fitment - Subaru WRX Forum
 2Likes
  • 1 Post By RoboTuner
  • 1 Post By mosc
post #1 of 6 Old 03-14-2017, 04:32 PM
07SubieWagon
Guest
Posts: n/a
Wheel fitment
New to subarus but was wondering what wheel size would i be able to run on my 2007 wrx wagon without any rubbing? It is lowered by previous owner.
post #2 of 6 Old 03-14-2017, 04:54 PM
get 17x8" +48 run 235/40R17 tires.
post #3 of 6 Old 03-15-2017, 05:49 AM
titter's Avatar
this is your best options for 02-07 WRX>
you might need to roll your fenders a wee bit to get them to fit since your car is lowered by the previous owner.
dont forget to wave
titter is offline
post #4 of 6 Old 03-15-2017, 12:44 PM
RoboTuner is known to be trustworthy and helpful RoboTuner is known to be trustworthy and helpful
I'd go 225/40R17 as you won't need to do fender work or use much camber, the wagons are much more narrow and the rear proves it with wide wheel/tire combos. 235/40R17 will work, but you'll need camber and fender work to not rub on a GG wagon. Note that 215/45R17 is the OEM tire size for the OEM 17x7 wheels, add another inch of width and you'll need to lower your sidewall a touch, thus the 225 or 235/40R17.
Also keeping the wheel offset close to OE as possible is very important. The factory wagon offset for the 16x6.5 paired with a 205/55R17 is +52-55, therefore when going wider you'll need to lower that offset 5-10 (10 at most) for every extra inch of wheel width to aid against rubbing (spring/spring perch/fender)...so for a 17x8 +45-48 would be ideal.
My 02 wagon has 17x7 +48 wheels from the BRZ, and they don't rub everrrr. I don't have any camber adjustments differing from the 16s and I'm stock height, this setup still leaves enough room for 17x8 if I use some negative camber (~ -1degree) as I can still fit 1.5-2 fingers
titter likes this.
RoboTuner is offline
post #5 of 6 Old 03-16-2017, 03:01 PM
I swear he said sedan. My recommendation is too wide for a wagon. I'd agree with RoboTuner for an 07 lowered wagon. 235 is difficult.
RoboTuner likes this.
post #6 of 6 Old 03-17-2017, 05:57 AM
titter's Avatar
+38 is the max you can go in a stock wagon if using stock 6.5" wide wheels. not that you would have +38 offset on a 6.5" wheel, but hey, whatever floats your boat. from there, math can tell you what will fit.
you can plug you OE spec into this calculator and really dial in your choices: https://www.wheel-size.com/calc/?whe...=30mm&scl=51mm
not knowing exactly how much your car is lowered from the previous owner might make things a bit difficult.
if you stay wagon width, watch out for too much camber as you can then start to hit your strut tower. also, if you go to a 8" wide tire, do not stay oem offset. you will want +50 at a minimum but +48-46 would be ideal. +55 in pretty sure will make contact with your strut tower. alot of people forgot about the inside clearance as well when fitting wheels & tires.
dont forget to wave
titter is offline
