Tein S Tech Lowering Springs for 08 WRX - Page 2 - Subaru WRX Forum
post #16 of 17 Old 12-28-2010, 11:03 AM
If you want to do it properly, you should replace the struts as well and get yourself some harder springs (not necessarily lower but they do turn out to be about an inch lower). Swift makes both cosmetic and correctly lengthed performance springs (be careful which you're getting) but unfortunately, I don't know where to point you for new struts. The D-spec struts generally recommended are only for the 02-07 WRX models.
Anyway, springs:
Turn in Concepts - 2008-2009 2.5i/WRX Swift Springs
You'll notice the drop is only 0.8". While you're at it, ask TiC about struts for your car maybe they can get creative for you.
post #17 of 17 Old 01-15-2011, 07:52 AM
tonyturbo13's Avatar
Originally Posted by brfatal View Post
Your car is different than mine so the choices are going to be different. I will tell that it's documented that your +09 struts don't like ANY lowering springs, which is why so many of your generation owners get coilovers. And good coilovers don't start under $1,500.
Too true, I'm running S Techs on my 09 and my front drivers side shock just started leaking, blown shock...
tonyturbo13 is offline
