Rubbing noise 11 WRX - Subaru WRX Forum
 1Likes
  • 1 Post By sebi1990
post #1 of 8 Old 07-30-2013, 02:58 PM Thread Starter
sebi1990's Avatar
Hi guys I've bought a 11 wrx with 17k miles on it it has aftermarket wheels which are 18s the tire size on the wheels is 245/40/18 Dunlap tires. The problem is that I not only get tremendous amount of road noise (tire noise) but also when I was taking a sharp right turn I heard rubbing sound coming from my rear left wheel also when I aggressively shift from 1st to 2nd I hear a very loud rub noise coming from the back. What might be causing the issue? Could it be just the tires going bad maybe clearance issue? I've read about bend start bars I hope that's not it however I still have bumper to bumper warranty with the car.
sebi1990 is offline
post #2 of 8 Old 07-30-2013, 09:42 PM
Is that some bad autocorrect?
post #3 of 8 Old 07-30-2013, 10:38 PM Thread Starter
sebi1990's Avatar
Thx for the help
sebi1990 is offline
post #4 of 8 Old 07-31-2013, 08:26 AM
Premium Member
the RIOT act's Avatar
You running a stock suspension setup? Those should fit if so...
You check your end links in the back? One could be broken and that would def cause it to rub being slightly larger than OE
Sent from AutoGuide.com App
Brandon - 13' SWP WRX Sedan
the RIOT act is offline
post #5 of 8 Old 07-31-2013, 12:01 PM Thread Starter
sebi1990's Avatar
I planning to take it to dealer have one of the techs ride with me so I can show him greatly appreciate your help I'll keep you posed.
the RIOT act likes this.
sebi1990 is offline
post #6 of 8 Old 07-31-2013, 02:09 PM Thread Starter
sebi1990's Avatar
I've figured out thanks to the guys on the forum that they are BBK replicas here is the link they look exactly like these. BBS Road Wheels Detail | BBS USA
sebi1990 is offline
post #7 of 8 Old 08-09-2013, 01:52 PM Thread Starter
sebi1990's Avatar
The dealer tried to sell me a car that was not inspected what happened was the inside of the wheel was rubbing against the shock haha I took it back and had quite a fight with the dealer and then talked to BBB I'm preordering a 2013 wrx white hatch and its going to be here on the 16th
sebi1990 is offline
post #8 of 8 Old 08-09-2013, 03:03 PM
Premium Member
Now you're talkin'....
