Racelands - Subaru WRX Forum
 3Likes
post #1 of 16 Old 12-15-2013, 06:28 PM Thread Starter
Subieblue03's Avatar
Subieblue03 is an unknown
Racelands
How good are raceland coilovers
Subieblue03 is offline
post #2 of 16 Old 12-15-2013, 11:02 PM
They retail for less than it costs reputable companies to MAKE some coilovers. Draw your own conclusions.
post #3 of 16 Old 12-15-2013, 11:15 PM
They are crap.
Move forward. Good coil overs will cost you thousands.
That being said, I happen to know a few members on here that run BCBRs and love them.
They are very cheap, but seem to be reputable.
If you're looking for a decent cheap CO. I recommend those.
Otherwise, go big or go home.
post #4 of 16 Old 12-16-2013, 07:31 AM
BC BRs are barely better than Racelands. If he actually needs coilovers (I'm assuming he doesn't race competitively), then he should spend the money and actually get something with R&D behind it.
post #5 of 16 Old 12-16-2013, 08:10 AM Thread Starter
I don't race I was just curious about them cause they are cheap
post #6 of 16 Old 01-06-2014, 06:23 AM
616guy is an unknown
Buddy of mine has ROKKOR's basically the same thing,ride decent nothing for track use though. Still wouldn't recommend these just due to the fact he made it 2 months before having to send them in to get rebuilt which cost him almost as much as it did to buy a brand new set.
616guy is offline
post #7 of 16 Old 01-06-2014, 10:56 AM
Vendor
PROImportTuners's Avatar
PROImportTuners is more helpful than not
If you are looking for quality inexpensive coilovers, We have had good experiences with Both D2 and Megan.
For a little bit more you could also go with Buddy Club or Tein, which are both very nice.
Check out the options on our website here: Subaru Impreza Coilovers
06_hawk_eye likes this.
PRO Import Tuners
PROImportTuners is offline
post #8 of 16 Old 01-06-2014, 12:38 PM
post #9 of 16 Old 01-06-2014, 02:04 PM
06_hawk_eye's Avatar
06_hawk_eye is an unknown
Race lands are for Volkswagens stay away from those junk .
Sent from AutoGuide.com App
06_hawk_eye is offline
post #10 of 16 Old 01-08-2014, 09:39 AM
If you actually want to improve your car's handling and are looking at coilovers that cost LESS than $2000, you are insane. If you want to lower your car as much as possible as cheaply as possible, everything mentioned in this thread will work fine... just factor in replacing them (and your spine) after 25k miles at the most.
post #11 of 16 Old 01-08-2014, 01:18 PM
You can get complete, bolt-on ready entry level coilovers for $1,400 that aren't junk for GD Imprezas. The newer models however, different story. Suspension Technique coilovers + new top hats or camber plates (whichever you prefer). Most other options actually worth the money they sell for are quickly approaching $2k.
post #12 of 16 Old 01-08-2014, 02:40 PM
arcticscythe's Avatar
Suspension is not somewhere I would try to save money, A good friend of mine rolled his car with cheap suspension and I wouldn't wish that on anyone. Good suspension is the difference between a safe ride and a death trap. While most performance parts companies charge for the "sticker" they also sink millions of dollars into good solid research and development. in the case of race lands suspension they look cheap, the finishing and weld lines are pretty sloppy. for the 600 i would grab some whitelines anti-swaybars and bushings to match.just my .02 cents but I wouldn't bet my life to save a grand.
my old man once said "There are 2 things on your car that you can never discount, brakes and suspension."
pzr2874 likes this.
arcticscythe is offline
post #13 of 16 Old 01-09-2014, 07:20 PM
The only thing I'd add to that is tires
turmic likes this.
post #14 of 16 Old 01-13-2014, 12:59 PM Thread Starter
Ok I read that a good spring strut combo I'd better than cheap coil overs what is a good combo
post #15 of 16 Old 01-13-2014, 01:28 PM
call up Rallysportdirect (dot com). The 03 WRX you actually have some options. KYB makes some decent struts that aren't available for later years. You can also spend a bit more and get the dspec struts. Spring wise if you go with dspecs, look at the RCE blacks or yellows depending on what you're looking for performance vs ride quality wise. If you go with a cheaper strut, I'd actually recommend tracking down some used 04 STi springs...
PROImportTuners may have some competitive options as well. 02-03 WRX's have more strut options than other years.
