-   -   need opinions on tire replacement (http://www.wrxtuners.com/forums/f139/need-opinions-tire-replacement-38570/)
pjkatz04 09-02-2013 01:07 PM
All --
One of my tires got slit right open by an expansion joint today. Instantly ruined. :notgood: Anyway, they are the stock three seasons with about 20,000 miles on them. Question: With that amount of wear, can I buy just one tire to replace the damaged one, or do I need to replace in a set due to the AWD?
Thanks,
Pete
06_hawk_eye 09-02-2013 01:20 PM
What do the other tires measure? It all depends on what thread the other tires are.
pjkatz04 09-02-2013 01:27 PM
i couldnt tell you offhand...will bring it to the shop this week...
pjkatz04 09-02-2013 04:27 PM
If, worst case scenario, I need to buy a set of four new tires does anyone have suggestions on which three seasons I should get?
mosc 09-03-2013 09:23 AM
Perfect time to throw some winter tires on your stock wheels and then when spring rolls around next year buy a second set of wheels with summer tires. Goodbye all seasons! No need for the other 3!
pjkatz04 09-03-2013 09:38 AM
haha normally excellent advice, except I already have winter tires and wheels and so im stuck getting replacement summers.... if it were October or nov and a little cooler I would definitely just swap and worry about it in april but its just still too hot for my winters... good looking though
turmic 09-03-2013 09:49 AM
[quote=pjkatz04;349930]haha normally excellent advice, except I already have winter tires and wheels and so im stuck getting replacement summers.... if it were October or nov and a little cooler I would definitely just swap and worry about it in april but its just still too hot for my winters... good looking though[/quote]
So, you're looking for dedicated summers then. Not, three seasons. Lol
mosc 09-03-2013 01:53 PM
Meh, you can drive winters in the summer. You just have to accept they'll wear out faster when it's hot. They work fine in the Summer traction wise, your typical all season is not much more than a performance winter tire with a more general purpose tire compound (wider temperature range, worse performance when it's cold but can take the heat). So no rush if you don't want to buy summers this year.
20k miles on 3x summer tires isn't much value there most likely. My summer tires will be lucky to see 20k miles before the recycling heap.
the RIOT act 09-03-2013 02:41 PM
Buying 1 new is without a doubt not an option seeing you've got 20k on them OP. what's your budget for 4 new? I'll throw you some recommendations with what you can afford.
brfatal 09-03-2013 04:27 PM
With 20k miles on the stock tires it's not worth getting a new one and shaving. I'd get a new set.
pjkatz04 09-05-2013 06:37 PM
ok so turned out that the other three were within tolerances so i just had to purchase one replacement tire. my plan is to just run down the three and then buy a whole new set. also, i realized after my post that they actually dont have 20k on them, since i switched out for winters once already. car has 20k. ha. so they prob have closer to 15k. either way, i went with the one tire since maybe it wasnt the best option in terms of performance or being all equal, but it was the cheapest.
arewmors 09-05-2013 07:02 PM
Some times cheap isn't better. It maybe better now but the damage that could occur from something could be more money in the long run from the damage done from being cheap. You may be okay this time but you never know.
the RIOT act 09-05-2013 07:18 PM
What's the tread depths OP if you don't mind me asking? Even with 15k they're prob not within tolerance. Your car, your rules...just trying to help.
brfatal 09-05-2013 11:07 PM
[quote=pjkatz04;351233]ok so turned out that the other three were within tolerances so i just had to purchase one replacement tire. my plan is to just run down the three and then buy a whole new set. also, i realized after my post that they actually dont have 20k on them, since i switched out for winters once already. car has 20k. ha. so they prob have closer to 15k. either way, i went with the one tire since maybe it wasnt the best option in terms of performance or being all equal, but it was the cheapest.[/quote]
What tolerances? Subaru's tolerances are 2/32" tread depth. A summer tire will wear thru that ~5-6k miles assuming they car is not driven hard. If you have 15k miles on them, you are well out of specs.
pjkatz04 09-06-2013 05:14 AM
i appreciate all the heads up. im not sure what the tread depths were on the old tires to be honest. but i took the vehicle to the dealer and they did the work. replaced it with the oem dunlops. plus the vehicles still under warranty. so i feel confident that they wouldnt screw me over, since itll be on their dime to correct the issue if something goes sideways.
