need new brake pads. suggestions? - Subaru WRX Forum
post #1 of 6 Old 10-21-2010, 03:49 PM Thread Starter
Kramericaa's Avatar
Kramericaa is an unknown
I am going to need new brake pads very soon, as I only have about 20% left. My rotors are still good, but I am contemplating the idea of going with 4 slotted/drilled rotors with the new pads. Anybody upgrade to that and notice much difference? If so what kind of rotors? and pads? To be honest the completely stock brembo set up is pretty impressive in my opinion. I plan on keeping the car only stage 2 and a daily driver. Just curious if you guys really think it is worth it to upgrade to drilled/slotted rotors? Thanks
Sold- 02 stage 2 rex
Hello- 05 stage 2 STi
Kramericaa is offline
post #2 of 6 Old 10-21-2010, 04:13 PM
The advantage of slots or drills is heat dissipation which honestly if you notice any improvement from on your street car I would say you're driving like a lunatic. What you will notice is a substantial cut in lifespan of pads and rotors. So to review, for a daily driver the parts are all negative and no positive.
Pads, I'd recommend hawk hps. Make sure your lines are also upgraded.
post #3 of 6 Old 10-21-2010, 04:22 PM Thread Starter
Kramericaa's Avatar
Thanks for the quick reply. Yea I kind of figured there was not point unless your were to track it often. But, I won't be doing any of that so I'll just stick with OEM replacements.(which seems to be more than sufficient)
post #4 of 6 Old 10-22-2010, 12:53 AM
HPS are low dust stock replacement pads. I personally would recommend something more in the performance category. The Ferodos I'm currently running are the best bad I've ever used on any car and they still dust less than stock. As for rotors, whatever is cheap.
post #5 of 6 Old 10-23-2010, 09:07 AM
Granted, mine are no Brembos (06/07 WRX 4 pot/2 pot brakes), but I'm pretty happy with the setup I have on my daily driven Stage 2 WRX:
Hawk HPS pads all around
Goodridge SS lines
ATE Super Blue DOT 4 synthetic fluid
Stock rotors
Gets the job done, average/low amount of dust, and feels slightly firmer than stock. I keep debating whether or not I'd like a set of drilled and/or slotted rotors... on the one hand, yeah, they may dissipate heat better than stock/smooth rotors, but I don't track my car so that feature is useless to me. Honestly, I think I'd be more concerned about the little bits of rust that would probably begin to show inside all the dimples because I notice things like that. At this point, I'm thinking I'll probably just go with a set of cheap stock replacement rotors when the time comes... and another set of Hawk HPS pads
post #6 of 6 Old 10-24-2010, 03:26 PM Thread Starter
Kramericaa's Avatar
Yea I'm leaning towards hawks on all four. My rotors are still good anyways so it would just be wasteful to get anything else.
