coil spring bushing - Subaru WRX Forum
post #1 of 7 Old 02-13-2011, 07:38 PM Thread Starter
fast02bugeye's Avatar
coil spring bushing
I finally found where the horrible scraping noise was coming from on the rear of my car. i hear it often at low speeds. I at first figured it was the wheel bearings, but those are fine. I also cant find the part or the actual name for it. It is the rubber bushing that goes between the coil spring and strut tower mount. It is broken and cauing the noise.
Whats it called and where can i find it?
02 subaru wrx
sti turbo, cobb tuner, 850cc injectors,3" catback, centerforce 2
-Jonathan
fast02bugeye is offline
post #2 of 7 Old 02-14-2011, 10:50 AM
It's a rubber bushing.... Call the dealer and ask.... Prevents the spring from "squeaking" against the strut seat.
Sorry i'm not much help... You sure yours it toast?
post #3 of 7 Old 02-14-2011, 09:46 PM
wagonracer's Avatar
It's a: 20375FC000 Rubber Seat R Lwr and a 20375AC030 Rubber Seat Upr. Subaruparts.com is my friend
wagonracer is offline
post #4 of 7 Old 02-15-2011, 09:37 AM Thread Starter
thanks, thats what im looking for. the one on the back passenger side is split. Anyways, it does it over small bumps and when backing up. Like if i push down on the rear bumper it will push down, stay there for a split second and make the creeking/popping sound as it rebounds. Are my struts probably toast as well? The axles and wheel bearing looked good.
02 subaru wrx
-Jonathan
post #5 of 7 Old 02-15-2011, 11:29 AM
How many miles ? 90K is about when they start to take a dump.... Unless you baby the car...
post #6 of 7 Old 02-17-2011, 11:54 PM Thread Starter
the car has 113K miles. It has 2" lowering prodrive springs on it. would i need to replace the upper strut mounts as well or should i just do new struts and a brace
02 subaru wrx
-Jonathan
post #7 of 7 Old 02-18-2011, 06:26 AM
113K... best bet would be to buy a whole new set of struts... Just my .02
