-   -   camber adjustments (http://www.wrxtuners.com/forums/f139/camber-adjustments-34610/)
Cheney 04-30-2013 08:38 PM
camber adjustments
Can Anyone tell me if you have to pull the wheels off the car to adjust the camber. I was told by a dealership it wasn't necessary after i couldn't find the key to my wheel locks. Just making sure they actually did the work since the tire roar is still there. They said it will go away after the tire wears correctly where it matches the others. BS or not i don't know.
:confused:
pzr2874 05-01-2013 08:30 AM
That's no BS.... if the wear on the tires were that bad b4, then to align it up correct will take some time. Did they give you a printout?
Are you talking the front or rears. No the tires don't need to come off. Better order a new key.
Cheney 05-01-2013 10:27 AM
The did give me a print out 1 rear was out of line and one front was out of line so they were working against each other. Thanks for your help i appreciate the info as always.
