Brembo brakes upgrade for my 02 - Page 2 - Subaru WRX Forum
 2Likes
post #16 of 32 Old 08-13-2016, 01:30 AM Thread Starter
mikea1's Avatar
mikea1 is a helpful contributing member
okay a change of plan once again ..looks like i'll be doing my brembo upgrade 1st before my fmic project... failed CA smog test today no big deal I was told I need to drive my car for the next 150miles for it to be ready for the final test inpection.. its stupid for me to install the fmic when I have a current smog issue lol! so i'll do my brembo 1st ...ill post some photos once I'm done
mikea1 is offline
post #17 of 32 Old 08-25-2016, 12:55 AM Thread Starter
mikea1's Avatar
Update .. my brembo calipers came today, SS lines and kartboy bracket .. rotors inbound
mikea1 is offline
post #18 of 32 Old 08-25-2016, 12:58 AM Thread Starter
mikea1's Avatar
btw. off topic mounted my fmic last Monday
titter likes this.
mikea1 is offline
post #19 of 32 Old 08-30-2016, 01:13 AM Thread Starter
mikea1's Avatar
okay so I did my brembo upgrade today the front was not that hard to do and it looks great.... then I started working on the rear brakes drilled the dust cover and guess what? yeah the e brakes wont work because of the larger rotor .. now i did some research again i'll need a thicker brake shoe in order for the e brake to work ..which so far the only supplier I can find that makes this thicker brake shoe is from United Kingdom it will take some time for this to be delivered and its expensive.. anybody knows a US seller?
mikea1 is offline
post #20 of 32 Old 08-30-2016, 05:47 AM
titter's Avatar
you just got the wrong rear rotors thats all. dont use them so you can return them for the right ones.
you need 316x20 sized rotors with a 170mm parking brake drum. you must have got the 316x20 with a 190mm parking brake drum. subaru make both, just go get the right ones.
316x20mm (5x100, 190mm parking brake)
316x20mm (5x100, 170mm parking brake) <---- you want this size
316x20mm (5x114)
There are multiple versions of this disc. just bring a measuring tape and get the right size if the years dont match. obviously dont bother with the 5x114 size.
dont forget to wave
titter is offline
post #21 of 32 Old 08-30-2016, 08:02 AM
Is the 04 sti stock rear rotors the "316x20mm (5x100, 190mm parking brake)" ones? I think that was the confusion previously.
post #22 of 32 Old 08-30-2016, 09:10 AM
titter's Avatar
to be honest, i not sure which is from which. it might be a EDM/JDM/USDM thing? my research tells me they are both from 04 STI. hence why i suggested bringing a measuring tape.
im seeing talk of DBA making a rotor this size. but still cant find the OEM setup. i think its JDM market since the V7 and V8's had 5x100 bolt pattern and brembos. but thats just a guess.
dont forget to wave
titter is offline
post #23 of 32 Old 08-31-2016, 12:48 AM Thread Starter
mikea1's Avatar
I ordered an 04 STI rear rotor but yeah its 190mm I just measured it .. I can not return this anymore had a shipping issue with the seller .. I don't want to deal with them anymore.. my only option right now is really to look for that thicker brake shoe ..I already found one here in the US ..KNS brakes its called Oversize park brake brembo conversion... but it cost $200
mikea1 is offline
post #24 of 32 Old 09-07-2016, 01:27 AM Thread Starter
mikea1's Avatar
My brake shoe finally came today I got this from the UK shipping only took like a week. The pad is like half an inch. thick. i'll install this next Monday..
mikea1 is offline
post #25 of 32 Old 09-13-2016, 12:37 AM Thread Starter
mikea1's Avatar
so I mounted my rear brembo brakes today 1st the dust cover needs to be removed. some they cut off the dust cover me I just drilled the welding spot of the dust cover..
mikea1 is offline
post #26 of 32 Old 09-13-2016, 12:41 AM Thread Starter
mikea1's Avatar
next painted the whole back plate with anti rust paint and install the thicker e-brake shoe..
mikea1 is offline
post #27 of 32 Old 09-13-2016, 12:47 AM Thread Starter
mikea1's Avatar
now found out the Kartboy bracket is NOT bolt on fit with the rear brembo caliper had to file it a bit for the caliper to fit...
mikea1 is offline
post #28 of 32 Old 09-13-2016, 01:09 AM Thread Starter
mikea1's Avatar
Another thing the bolts for the caliper that came with the Kartboy kit it does NOT fit the caliper you will need the original brembo mounting bolts...
mikea1 is offline
post #29 of 32 Old 09-14-2016, 08:10 AM
titter's Avatar
lookin good bud!
dont forget to wave
titter is offline
post #30 of 32 Old 09-15-2016, 12:51 AM Thread Starter
mikea1's Avatar
Originally Posted by titter View Post
lookin good bud!
Thanks! a huge huge difference from my stock brakes. Now back to my hybrid engine hopefully I can mount it by Oct.
mikea1 is offline
