-   -   Anyone with 16" wheels and wide tires? (http://www.wrxtuners.com/forums/f139/anyone-16-wheels-wide-tires-40826/)
n8mcd 10-31-2013 12:19 AM
I just wanted to see if anyone had wider tires on some 16s... Pictures would be awesome as well as wheel specs (width/offset) and if it's lowered how much? I'm looking to try and stuff some 235 or 245/50/16s on my car with my 7.5" wide wheels with 48 offset... Just wanna see what it might look like... I'm lowered 1.5" front and back and I'm pretty sure I'll have to roll the rear fenders.
Thanks
Nate
psinuse 10-31-2013 08:23 AM
I ran a set of Goodyear Eagle F1 EMTs that were 245/45/16 on stock 03 WRX rims. No rubbing, but that was stock ride height.
brfatal 10-31-2013 09:52 AM
Only way you would rub with those configurations is if you have a wagon.
n8mcd 10-31-2013 01:42 PM
[quote=psinuse;387834]I ran a set of Goodyear Eagle F1 EMTs that were 245/45/16 on stock 03 WRX rims. No rubbing, but that was stock ride height.[/quote]
Any pictures if that? I was under the impression 225 was as wide as you could go on the stock rim width? How did it handle?
brfatal 10-31-2013 09:51 PM
[quote=n8mcd;388146]Any pictures if that? I was under the impression 225 was as wide as you could go on the stock rim width? How did it handle?[/quote]
It is unless you're in a motorsport setting where oversized tires can benefit you. Running wider than 225s on stock 6.5" will void the manufacturer warranty (motorsport tires don't generally have one) and you will have sloppy side walls.
n8mcd 10-31-2013 10:55 PM
My warranty is done by far lol... Hmmm... I wish I could find some pictures of 245s on stock wheels... My stock wheels look really nice
brfatal 10-31-2013 11:09 PM
I'm talking about the tire warranty. 245/45/16 requires a 7.5" wheel to be within specs. 245/50/16 requires a 7" one.
Neither of these should be run as your normal setup. If you find a set of '98-01 RS wheels, have at the latter size.
