12-06-2012, 11:36 PM
#7 (permalink)
Originally Posted by boostandlow
The ride height plays next to no difference in the wear and tear on the tires. This will be my third vehicle with the air ride never had that issue before. You do however, need to have your alignment done when you set the camber..
You are wrong unfortunately. Lowering the car from where the previous alignment was done not only increases camber but also toe in. Both can affect tire wear, more-so the toe.
The reason for the addition time over a regular coilover install is exactly what you mentioned. You're still installing 4 damper assemblies and having to do additional compressor and wiring installation.
