06 tr cv joints - Subaru WRX Forum
post #1 of 9 Old 02-24-2011, 04:32 PM Thread Starter
trouble0667's Avatar
trouble0667 is an unknown
06 tr cv joints
my suby just started making loud clunks when turning and hitting bumps. went to parking lot & did some tight turns . AS soon as I put pressure on the outer wheel by going a little faster I get a constant clunking at the outer wheel. The only suspension mods are Perrin swaybars. Im want to know if anyone has had this happen . my car has 60000 miles would cv's be bad allready? seems like it! Any feedback would be helpfull.
trouble0667 is offline
post #2 of 9 Old 02-25-2011, 05:40 AM
That or tierods. Have you checked your sway and links ?
post #3 of 9 Old 02-25-2011, 09:16 AM Thread Starter
Ive checked, that stuff its all tight. ball joint,tierods,wheel bearing,a-arm bushings,strut plate,springs are seated and not broke. Im still running those tie-rod style stock end links they feel tight but Ive been wanting to replace those anyhow.pretty sure its cvs 60000 miles just seems fast has anyone else replaced them that fast?
post #4 of 9 Old 02-25-2011, 09:33 AM
It's the same as struts... every1 drives different and go out at different times. Buddy replaced his CV's at 72K... So it's prob right.
post #5 of 9 Old 02-25-2011, 09:56 AM
Aw crap, I have 76k... is there an obvious way to tell that a CV joint is bad besides looking for tears in the rubber boot? Maybe that's the cause of my front end noise too... happens mostly when I back up into parking spaces though. Could also be a sway bar/endlink issue.
post #6 of 9 Old 02-25-2011, 11:31 AM
They eventually wear... His boots had no tears or accidents...
post #7 of 9 Old 02-26-2011, 08:49 PM Thread Starter
no tears or leaks in my boots either. I do tend to nail the thottle as Im rolling thru a curve.also when i pass some lesser vehicle my foots in it. With 357 WH this certainly would be able to trash a CV early.
post #8 of 9 Old 03-03-2011, 04:07 PM Thread Starter
turns out the clunk was a wheel weight hitting the sway bar.. i put on a new sway up front and rotated tires at same time.a few months ago. only one wheel has a clip weight on the inner lip of the rim. all the rest have tape weights. some tire guy! I wont use that place again.
post #9 of 9 Old 03-03-2011, 08:01 PM
Cool, thanks for the update man. This should help some people.
