OK this is something that has been covered, that is likely why there have been no replies. Try searching using several keywords in the future.
Front suspension on all 02-07 WRX is identical wagon or sedan.
Rear suspension:
02-03 is the same (wagon struts have more camber I believe) wagon springs are also taller height
04-07 is the same (wagon struts have more camber I believe) wagon springs are also taller height
The strut mounts and the top of the strut stud are different. You can interchange between them ie use 02-03 rear susp on 04-07 or the same in reverse (must use same year strut, spring and strut mount)
There are also adapters to allow you to use 02-03 struts with 04-07 suspension.
