02 wrx struts - Subaru WRX Forum
 1Likes
  • 1 Post By PROImportTuners
post #1 of 5 Old 03-12-2014, 05:17 PM Thread Starter
cwheeler12 is an unknown
02 wrx struts
will 2004 sti sudan struts work on my 02 wrx wagon? or would it be better to go with some after market ones?
cwheeler12 is offline
post #2 of 5 Old 03-13-2014, 01:33 PM
Sedan yes, the 04 Struts work. Wagon? I don't think they're what you want even if they fit (which I dunno wagons well enough to tell you). Get some d-spec wagon struts.
post #3 of 5 Old 03-13-2014, 06:51 PM
Vendor
PROImportTuners's Avatar
PROImportTuners is more helpful than not
D-Specs are basically discontinued in this country for now.
Tokico US has been shutdown for a little over a year and everyone that I know of has long sold their old D-Specs for the WRX. Best bet these days if you want a good adjustable shock is the Koni Sport inserts.
You could use your 02 housings or the 04 housings with the Koni inserts. Both will work.
LW_Black4 likes this.
PRO Import Tuners
PROImportTuners is offline
post #4 of 5 Old 03-17-2014, 09:32 PM
You'll need new rear top hats to fit them. You should replace the fronts too just due to wear.
That being said '04 STI struts are already 11 years old. Most of these cars are going to have HIGH mileage, more than you want when it comes to buying new struts. If they are new, incredibly low mileage, or you plan on rebuilding them though, that's a different story.
post #5 of 5 Old 03-18-2014, 08:46 AM
Ya, STi struts are generally OK to just re-pack and re-use if they get worn. What kiss em is rust.
