Go Back   WRX Forums > Supporting Vendors > Tuner Tools
» Sponsor Links
»Garage Storage and Cabinets
Old 09-14-2008, 11:51 PM   #1 (permalink)
TunerTools's Avatar
Car: 2004 SSR
Reputation: TunerTools is an unknown
Send a message via AIM to TunerTools
New Touch Control Shift Lights from Gizzmo Electronics
Public Notice: Gizzmo Electronics has released two new shift lights and a tachometer converter/adaptor which are all now shipping!!
These all new DSII dual stage shift lights incorporate touch control, the DSII-L includes support for the Gizzmo Electronics Launch Control Interface, both include 3 levels of control over the brightness, the size has been made incredibly sexy and the pricing is lower than the previous models!!
For a size comparison with the original Gizzmo Electronics Shift Light click here.
New ( AND lower!) pricing on these shift lights!!
The new Tach Recall TRII Shift Lights will be released within a few more weeks and also incorporate many of the adjustments of the DSII models.
The DSII and DSII-L as well as the TA1 Tachometer Converter are all available now for purchase on this website or from any of our GizzmoUSA authorized dealers. The DSII & DSII-L are clearly the best shift light on the market and going fast. So get yours while they're in stock!
Gizzmo DSII 'Touch' Dual Stage Shift light p/n G0910
The Gizzmo DSII Touch Shift Light has a Super Tiny profile of 13mm X 61mm (.5in X 2.4in) and weighing a mere 49 grams (1.7oz) complete with loom. Within the 100% Carbon Fiber case is a full Microprocessor sampling your RPM signal in 16bit resolution at 0.0000045 of a second (222,222 times per second).
Click for more details: p/n G0910 MSRP: $99 USD :
For Dealer & Distributor Pricing: Contact GizzmoUSA :
Gizzmo DSII-L 'Launch' Shift Light w/Launch Support p/n G0909
The Gizzmo DSII Launch Shift Light is similar to the DSII 'Touch' plus it includes support for the Gizzmo Electronics Launch Control Interface. The Shift Light has a Super Tiny profile of 13mm X 61mm (.5in X 2.4in) and weighing a mere 49 grams (1.7oz) complete with loom. Within the 100% Carbon/Kevlar case is a full Microprocessor sampling your RPM signal in 16bit resolution at 0.0000045 of a second (222,222 times per second).
Click for more details: p/n G0909 MSRP: $129 USD :
Gizzmo TA1 (Tachometer Adaptor Version 1) p/n G0903
Gizzmo’s TA1 is the perfect solution for making a factory tachometer work as it was intended after you have retrofitted an aftermarket engine. The TA1 also is a perfect solution for when you have a newer vehicle with a CAN communications dash that does not have a tachometer signal for you to tap an aftermarket tachometer into. The TA1 Tach Adaptor allows you to tap into an ignition amplifier/igniter or ECU tachometer signal and multiply/divide this frequency to line up with your OEM or aftermarket tachometer. Please note that this device cannot be wired to high voltage source such as coil negatives or CDI outputs.
Click for more details: p/n G0903 MSRP: $69 USD :
Cheers,
Lloyd
www.GizzmoUSA.com
[posts] Report this Post to a Moderator
