Wastegate Flutter? - Page 3 - Subaru WRX Forum
post #31 of 47 Old 03-16-2011, 04:30 PM
If u guys are leaking then the flutter sounds like you might be over boosting the turbo. Since theres a leak the turbo is really pushing like 25psi but because of the leak the manifold pressure isnt getting up there. Its probably the turbo screaming enough!
Baumgartend we dont have Y pipes. Are intercoolers are different.
08DGM sounds like you may have fixed the leak but by touching everything. Hows the old turbo look and its operation.
post #32 of 47 Old 03-16-2011, 04:50 PM
08DGM's Avatar
08DGM is an unknown
Ya I honestly don't think it was the turbo. My old turbo seems to function fine, though it has a bit of shaft play. I think more than anything that it was the loose intercooler hose I found in the process of replacing the turbo. No worries though, I got to do my first turbo on a Subaru and now I have a fresh turbo.
08DGM is offline
post #33 of 47 Old 03-17-2011, 12:19 AM
whats hose exactly?
post #34 of 47 Old 03-17-2011, 03:12 PM
08DGM's Avatar
08DGM is an unknown
Originally Posted by synolimit View Post
whats hose exactly?
The hose clamp on the hose that runs underneath the bov was lose.
So I took my car out and wanted to drive it around for a bit before I take it for a new tune tomorrow, and it sounds like it's fluttering again. It's boosting over 15 psi now, up to 18, but I can still hear a flutter. I guess I need to build me one of the caps and test it for leaks.
08DGM is offline
post #35 of 47 Old 03-17-2011, 05:28 PM
hmm not sure what you mean. the BPV bolts to the TMIC, it has a 1" hose that runs to the turbo inlet, on the top of the BPV theres a vaccum line that runs to the manifold on the left side of the throttle body, and theres the TMIC to TB coupling.
post #36 of 47 Old 03-18-2011, 12:19 AM Thread Starter
The worm drive clamp for the tmic to throttle body hose is right under the BPV.
post #37 of 47 Old 03-18-2011, 04:59 PM
see thats what im thinking but i thought he'd say TB coupling then.
08DGM if that is what your talking about its a known fact that the silicone slips on the ends of the kevlar TB coupling allow the kevlar TB coupling to slide off the TB or TMIC. TMIC's dont have as bad of a time because of the TMIC bracket that bolts it to the manifold. everyone takes the silicone ends off the coupling for a more positive seal. for FMIC's its a must. mine would blow off the second i hit boost no matter how tight it was.
post #38 of 47 Old 03-19-2011, 01:31 AM
08DGM's Avatar
08DGM is an unknown
Ya you guys nailed it on the head. That is indeed where it is leaking from. So I can just remove that silicone piece for a better seal? I guess I'll be doing that tomorrow.
08DGM is offline
post #39 of 47 Old 03-21-2011, 01:59 PM
Subbie's Avatar
Subbie is more helpful than not
Syno,
What pressure did you set the compressor to for your test?
"Dustin"
- 08' WRX Premium - SOLD
- 08' Yamaha R1 - Top Speed seen is 204 - SOLD
Subbie is offline
post #40 of 47 Old 03-22-2011, 12:07 AM
Its always set to the max. You cant put to much in because the evap system kicks in and starts leaking it off.
post #41 of 47 Old 03-28-2011, 01:58 PM
Subbie's Avatar
Found the leak... It was the hose on driver side going to the intercooler. Damn thing was so loose I could turn it with one finger. No more boost leaks...Now I am reaching a nice and strong 18.1 PSI. Feels like a whole new car!
"Dustin"
Subbie is offline
post #42 of 47 Old 03-28-2011, 02:03 PM
Congrats! Boost leaks and be a biotch to locate sometimes!
post #43 of 47 Old 03-28-2011, 09:58 PM
Can be* LOL, sorry Matt I had to. I mess up more than I'd like to admit at times.
post #44 of 47 Old 03-28-2011, 11:08 PM
stupid auto-correct on teh iPhone
post #45 of 47 Old 03-29-2011, 01:03 AM
Hondafan's Avatar
OT, but it's funny that it didn't catch teh for the.
Glad to hear your leak is gone. I still think it'll be a nightmare to test for leaks if my car ever needs it.
-Brad
Hondafan is offline
