VF 52 max boost - Subaru WRX Forum
 7Likes
  • 2 Post By psinuse
  • 1 Post By pzr2874
  • 1 Post By Claythrow
  • 1 Post By synolimit
  • 2 Post By BLAZE2099
post #1 of 11 Old 11-14-2013, 09:30 PM Thread Starter
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
VF 52 max boost
What is a "SAFE" max boost a VF 52 can hold with out blowing up eventually?
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #2 of 11 Old 11-14-2013, 09:38 PM
Premium Member
arewmors's Avatar
The Cobb stage two is conservative being at 18psi for the regular waste gate and torque performance has a stage 2 map at 19psi. I'd go out on a limb and say 19-20psi max
Andy - 12 WRB WRX
Tuned by Innovative Tuning
294 AWHP / 311 TQ
arewmors is offline
post #3 of 11 Old 11-14-2013, 11:26 PM
Max boost is a relative term. Can you run 30 PSI on a VF52? Yes, will it be efficient at 30 PSI? Hell no, it'll probably run like dog dirt. Its whatever boost you need to get the best effect out of the turbo is your max boost. That can vary from car to car and turbo to turbo. Which is why a protune is so much better than a generic safe OTS map.
post #4 of 11 Old 11-15-2013, 06:08 AM
It can run enough boost to propel you into the 11's, which is enough.
pzr2874 and turmic like this.
post #5 of 11 Old 11-15-2013, 09:07 AM
Sorta like "Freedom Rock"
psinuse likes this.
post #6 of 11 Old 11-15-2013, 11:49 AM Thread Starter
Premium Member
Nathan21's Avatar
Well I am do the point after my DP, that I will be buyng a bunch of parts slowly and waiting till I get enough to do a protune, just wanted to make sure that it would be worth my while keeping the vf52 or upgrading to something bigger.
But I also want to make it a reliable DD, which I don't know where that line lays
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #7 of 11 Old 11-16-2013, 11:56 AM
It depends on how you drive it.
post #8 of 11 Old 12-25-2013, 03:29 PM
Claythrow is an unknown
^^ Exactly. 20 is the most you can go, I've had them personally & I never went above 14 or so. Just because something is capable of a certain benchmark doesn't mean you want to push it to that benchmark all the time. I try to dial everything back 25-30% for longevity. Sometimes this requires going bigger.
E.G. If I needed 20 7 of boost I would go with a bigger turbo than a VF. Something capable of 27-30 & dial it back to 20. But thats just me. But, you'll see me driving the same car week in & week out, not showing up at the meet with a new turbo, new this or new that because I pushed it too hard & broke it.
There is no such thing as "overkill," but there is "over budget," so it's a balancing act.
Nathan21 likes this.
Claythrow is offline
post #9 of 11 Old 01-03-2014, 02:57 PM
Depends where you want the max at. Down low 22-23 psi worked for me. Up high only 15-16 psi worked for me. Any higher and you start blowing hot air and knocking which means you pull timing and lose power. Its a fine line with boost and timing. Both can make about 10hp for every psi or degree increase but tipping the scales on one or the other will result in knock.
the RIOT act likes this.
post #10 of 11 Old 01-03-2014, 04:56 PM
Look who's back
synolimit and the RIOT act like this.
post #11 of 11 Old 01-20-2014, 02:09 AM
Sub14WRX's Avatar
Sub14WRX is more helpful than not
20-22PSI sweet spot.
Sub14WRX is offline
