i'm stuck with 3 choices on which turbo to use. currently i have a stock tmic, 3" turbo back catless exhaust, cobb stage 2 map. next on my list is injectors, pump, turbo and CAI. these are what i've found and are listed as follows:
VF52 Turbocharger Combo 2 $1475
Deatschwerks Top Feed 750cc Injectors w/ Walbro Pump and Tomioka TD05-18G Turbo $1400
Deatschwerks Top Feed 750cc Injectors w/ Walbro pump and Tomioka TD05-20G Turbo $1650
vf52 claims 320whp if used with 650cc and protune
TD05-18g claims up to 350whp
TD05-20g claims up to 400hp
is anyone running the vf52 with 750 injectors? Or any of the other mentioned turbos? what whp are you seeing?
My aim is low to mid 300whp range without having to max the turbo on boost, leave some room to grow if the occasion calls for it. i might just grab the injectors and pump first but am still on the fence on which turbo to use. i haven't heard about tomioka, but they are within my budget, and er'body knows the vf52. i'll still keep searching the forums for answers to my questions but look forward to yalls input. thanks!
