turbo choices for the 08 wrx sedan - Page 5 - Subaru WRX Forum
post #61 of 81 Old 08-07-2011, 11:51 PM
black beast2's Avatar
^ 400whp is possible with the 20g, I'm real close to that on E85 only boosting 20psi because of my small top mount. I would be hitting 400whp if I ran only one more psi add a couple and would definitely hit that number. All I would need is a fmic to turn up the boost a little. Yes I dyno on a mustang as well. Probably not gonna happen on pump gas tho, not even close with 91.
black beast2 is offline
post #62 of 81 Old 08-08-2011, 08:11 AM
Originally Posted by brfatal View Post
I already told you those numbers are bogus.
CXR - 340-360 whp
VF52 - 290-300 whp
18G - 300-330 whp
20G - 330-350 whp
[edit] Ah, 91 octane. Take ~20-30 whp off those numbers.
I only hit about 275 on airboy with the vf52 on 91 @ 4,200'... That was with a lot of supporting mods too.
I would still consider the blouch 440xt or 480xt as viable options as well. Those are basically 18 or 20g's designed to bolt up to the stock layout style TMIC. They're a bit pricier, but you would save money or at least break even by not having to buy the process west TMIC ($$$) or an FMIC ($$$-$$$$)
post #63 of 81 Old 08-09-2011, 01:59 AM
^So brfatal was right on by saying take 20-30whp off for 91 oct, putting you at 275 instead of 290-300.
Also I'm pretty sure all the turbos the op mentioned are direct bolt on to the stock layout. The only one I'm not sure about is the CXR, I know all the other ones are a direct fit.
post #64 of 81 Old 08-09-2011, 08:15 AM
Ah, I'm always thinking about a blouch 20g, not the deadbolt style modified OEM compressor housing.
My steps have been pretty linear...
270/295ish on 91
300/325 on 93
338/341 so far on E85 (same boost target as 93 tune is why the tq is pretty low)
That last one is on the romraider dyno though, airboy didn't like the log my tuner emailed me. Final tune is this weekend and I'll get a proper airboy number. It'll probably end up right about where it's at right now and we'll be adding a bit of power.
post #65 of 81 Old 08-09-2011, 03:35 PM
So does anyone wanna guess what I'm making on my 20g car???? I'm running a TDO6 for the record...Mods are in my profile...hehe
post #66 of 81 Old 08-09-2011, 04:21 PM
Is it a ebay TD06 or some other brand? Will factor into my guess. And hint us at what rpm your making peak horsepower . Seems like you were spinning ridiculously high.
cwinterbower is offline
post #67 of 81 Old 08-09-2011, 04:54 PM
What psi are you pushing, your profile says 21psi but it also says 264whp on stock turbo so I assume it needs updating.
I don't have to be mad to punch someone in the face!
post #68 of 81 Old 08-09-2011, 05:01 PM
I believe he is running a tomioka turbo.
With what I have to base my opinion off of I would say your putting down 342 whp.
post #69 of 81 Old 08-09-2011, 05:16 PM
Gonna guess on a built motor spinning hard on pump gas, 350ish as well.
post #70 of 81 Old 08-09-2011, 06:16 PM
Oh crap sorry didn't realize that was still on there...err have to change that and 264whp wasn't the stock turbo that was a hybrid turbo that I build...
MHI TDO6 20g 7cm2 650cfm IWG<--I know I should go EWG, but it's my DD
2.34L 8700 redline(no the turbo doesn't hold full boost to redline)
24psi
Give you a hint: at 18psi I'm trapping 90mph in the 1/8 mile.
post #71 of 81 Old 08-11-2011, 04:29 AM
So, are you ready to kill us with your numbers yet?
post #72 of 81 Old 09-13-2011, 09:25 PM
im back
Originally Posted by synolimit View Post
yet whats it matter what i run??? if 2 or 3 other 09's with VF52's all show around 340whp and all of us are on different dyno's and they put down 12.0 in the 1/4, i think its safe to say we all put down around 340whp and can run 12.0 in the 1/4!! geez!
if i was the only one you could argue more but since more than 3 of us show that HP and they have been to the track with 12.0's, its pretty damn fair to say what im saying!
and yes my car is "magically" 200lbs lighter than factory. its called removing stuff. Please use your head next time before you make smart comments. like removing stuff is the hardest thing in the world to do and i need magic to preform it, come on man you know more than this!!
You must be talking about me haha.....honey im back and building an 11
11.82 at 116mph
stock turbo 2011 wrx
337whp 411tq
djc1827 is offline
post #73 of 81 Old 09-14-2011, 12:05 AM
i was, funny, so i am. the race is on again. who gets to 11 first.
post #74 of 81 Old 09-14-2011, 08:27 AM
May the best man win or break something in the process lol
11.82 at 116mph
337whp 411tq
djc1827 is offline
post #75 of 81 Old 09-16-2011, 12:00 AM
Shit I was 2 100ths of a second away on 18" rims, wanli tires and heavy premium wrx. You can hit 11s with 20g or 30r wow...good luck holding your motor together...Did i mention my 2011 is lighter car, lighter wheels, sticky tires, some colder weather or maybe a fmic...its a done deal at 11.6 or 11.7 all day at 115 116 mph
11.82 at 116mph
337whp 411tq
djc1827 is offline
