Tune? - Page 2 - Subaru WRX Forum
 16Likes
post #16 of 20 Old 04-23-2014, 11:45 PM
Get a base map from your tuner and flash it.
Also change your oil as you could very well have some fuel mixed into your oil pan right now. Gasoline is not as great of a lubricant as oil, comparatively speaking of course.
BLAZE2099 likes this.
post #17 of 20 Old 04-24-2014, 03:38 PM
bluestreak is an unknown
I did a turbo swap and some other mods (don't trust shops) and had a custom map from a well known tuner (etune) loaded before I started it for the first time. It idled great!
Of course, this is the kind of paranoia you get when you're on your 2nd sti
Live and learn.
boo-key likes this.
bluestreak is offline
post #18 of 20 Old 04-24-2014, 04:46 PM
konawrx
Guest
Posts: n/a
how would i load a etune map without an AP? and i have a mac if that makes a difference.
post #19 of 20 Old 04-24-2014, 06:12 PM
Laptop and tactrix cable
post #20 of 20 Old 10-09-2014, 03:15 PM
SubieDylan is an unknown
Originally Posted by konawrx View Post
so i just did a major upgrade to my wrx including a blouch 16g, new 850cc injectors and fuels pump and invidia turboback exhaust. i have not gotten a tune yet and im wondering if that is what is causing the loss in power and all around rough drive. i know a tune is required but i didnt expect the car to have zero power without one. is this normal? or did i perhaps install something wrong? there are no leaks oil or gas, and the car idles fine, a little lower than what im used to before install but i can tell fuel pump is working. just wondering if this is standard performance b4 tun or what?
You need to get a tune ASAP (rocky).
All of the upgrades you previously mentioned REQUIRE a tune to function properly, and give you the power you SHOULD be getting.
SubieDylan is offline
