Tgv deletes - Subaru WRX Forum
 3Likes
post #1 of 16 Old 10-28-2013, 02:00 PM Thread Starter
NeverSummer's Avatar
Tgv deletes
Can someone shed some light on this subject to me? I'm doing rails in my car this week and someone mentioned to do the tgv deletes. Anyone w any personal exp w this?
Sent from AutoGuide.com App
NeverSummer is offline
post #2 of 16 Old 10-28-2013, 02:17 PM
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
Ive always been wondering about this myself as well!!
Looking forward into seeing the way this goes!!
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #3 of 16 Old 10-28-2013, 02:53 PM
Basically you take out the butterflies and rod that go in the TVG housings. This allows air to flow better into the intake runners. They are there for emissions purposes. You would also need to shut off the codes or the car will not run correctly. You can tune for this by richening the start up fuel parameters, but I have found the ECU actually corrects for this by itself.
post #4 of 16 Old 10-28-2013, 03:26 PM
LW_Black4's Avatar
Great info, psinuse.
I intend to delete the TVG when I rebuild my fabulous little EJ205 twin-cam turbo engine.
Laszlo - white '11 STi sedan
LW_Black4 is offline
post #5 of 16 Old 10-28-2013, 03:49 PM
Haw1es's Avatar
Haw1es is more helpful than not
Ok, so the tgv are there for emissions purposes what do they actually do? Do they control/limit the amount of air that enters the manifold?
Shane
2010 WRX
2014 F150
Haw1es is offline
post #6 of 16 Old 10-28-2013, 05:06 PM
Tgv Deletes
post #7 of 16 Old 10-28-2013, 05:36 PM
Haw1es's Avatar
Thanks pzr2874!
I probably should have just searched first myself
Shane
2010 WRX
2014 F150
Haw1es is offline
post #8 of 16 Old 10-28-2013, 06:35 PM
Wow the number of people on that thread that no longer own a Subaru or even post on here anymore...
Nathan21 likes this.
post #9 of 16 Old 10-28-2013, 11:28 PM
They also help the car start up on a cold day...which with E85 might help out.
post #10 of 16 Old 10-29-2013, 09:41 AM Thread Starter
I do alot of Vermont trips in the winter to snowboard. I'm curious of deleting the tgv is gonna screw me? I wont be on e85 during ling trips like vermont. I won't be e85 too much longer to be honest. I'll prob be on it till the meet then that's it
post #11 of 16 Old 10-29-2013, 10:07 AM
LW_Black4's Avatar
TGV Delete FAQ: TGV Delete FAQ: Read if you are thinking of buying one! - NASIOC
And I'm considering removing just the TGV butterfly plates and leave the rod and actuators in, to avoid any CEL code issues.
post #12 of 16 Old 10-29-2013, 10:19 AM
I know I've heard conflicting reports about it, but I've heard that the error is all that needs to be removed and I've heard that it can cause the car to run lean everywhere and needs to be compensated for. Having never tuned I don't have an experience. I would just ask your tuner what they think just to make sure.
turmic likes this.
post #13 of 16 Old 10-29-2013, 04:02 PM
Just remove everything. It's not as hard as it seems and the only real pita is grinding down the divider plate. Tuning as I said a little bit of enrichment, but nothing super crazy really needs done. Unless your running serious boost it's not worth doing unless you already have to take the intake off anyway and even then.
the RIOT act likes this.
post #14 of 16 Old 10-29-2013, 04:18 PM
boo-key's Avatar
Agree with the grumpy ol' cat ^. If your gonna do it, do it all or nothing. Like he said, its really not hard. I did my own. I bought a set ahead of time and deleted them. Then sold my stockers. No downtime that way.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #15 of 16 Old 10-29-2013, 05:51 PM
What would you be filling in the rod holes with? JB?
