supporting mods for vf52 - Subaru WRX Forum
post #1 of 41 Old 07-25-2012, 08:31 PM Thread Starter
sugeina is an unknown
i'm planning on upgrading the stock turbo on my 08 wrx to a vf52 (same one on the 09wrx). i read in the unabomber's manifesto that the 08wrx and the 09wrx have the same intercooler/fuel pump/injectors. my question now is, are there other minimum required supporting mods i should get? how about recommended just-to-be-safe mods? and nice-to-haves?
sugeina is offline
post #2 of 41 Old 07-25-2012, 09:22 PM
You plan on getting it tuned correct? If so look into a fuel pump, down pipe and 3 port boost control solenoid also.
post #3 of 41 Old 07-26-2012, 08:37 PM Thread Starter
yes, will definitely have it tuned after.
from my googling research, the stock fuel pump of the 08wrx is the same as the 09wrx's.
downpipe, yes, i plan on getting the invidia catted dp.
is the 3 port boost control solenoid required? or recommended?
sugeina is offline
post #4 of 41 Old 07-26-2012, 09:40 PM
wrx3r's Avatar
wrx3r is more helpful than not
I am out of the loop with new wrx, but you will want to talk to your tuner to ensure you will not be making out your stock fuel pump and injectors on the tune he is planning for you.
bigger and better than ever
wrx3r is offline
post #5 of 41 Old 07-27-2012, 01:33 PM
Stock fuel set up is fine for stage 2. It will show maxed out but it's not. The stock Ecu is dumb vs aftermarket stand alones. Stock can show as high as 115% duty cycle which would be impossible. More stuff u actually add on the better you help out your fuel system. I know that sounds weird but everything stock is very restrictive so putting bigger things on eases the stress and you flow a little less fuel.
3 port isn't really needed. Not till you're well above 20 psi for a long time.
post #6 of 41 Old 07-29-2012, 04:11 AM Thread Starter
Alright, got it. Thanks!
sugeina is offline
post #7 of 41 Old 09-20-2012, 12:22 AM Thread Starter
so, i got a vf52 already and an invidia catless downpipe (everything else, stock).
haven't talked to my tuner yet as he's still out of town.
can i expect to exceed 300whp already with this setup?
sugeina is offline
post #8 of 41 Old 09-20-2012, 06:35 AM
Nope...
post #9 of 41 Old 09-20-2012, 09:38 PM
BoostinChick is a helpful contributing member
....maybe on E85 and a super aggressive tune. But then you need injectors and a pump.
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #10 of 41 Old 09-21-2012, 02:19 AM Thread Starter
Nope...
hmm... how about 270whp?
would adding 650cc injectors and a 175lph pump do the trick? or do i need to upgrade the tmic also?
sugeina is offline
post #11 of 41 Old 09-21-2012, 09:25 PM
Need a 255lph fuel pump. TMIC upgrade would help.
post #12 of 41 Old 09-22-2012, 01:43 AM
U can hit 300hp if its a lower reading dyno. The number doesn't matter, the increase does. Find out what his dyno reads first and you should be around a 70hp increase over stock. Up grading the fuel system won't help because there are other things that need addressed first. The whole intake system needs redone. Intake, tmic, tgvs etc. also the exhaust sucks, header, ewg etc will really open it up and take the stress off your fuel system. I was running stock injectors to 330hp and 360tq on a dynojet that read around 230hp 240tq stock. That equals 21psi down low to make the tq and 15.5psi to make the hp up top and I only got to 94% duty cycle which is low by some tuners standards. There are a million ways to make power on these cars! Sadly part by part only adds a few small ponies here and there. Only way to make bigger, cheaper power is E85 or a bigger turbo.
post #13 of 41 Old 09-22-2012, 08:29 AM
Remember winter time, the "e85" content can dip to e70 in most places.
post #14 of 41 Old 09-22-2012, 09:55 AM Thread Starter
Alright, so i want a 120whp increase. I already have a downpipe and a vf52.
What else is the minimum that i need?
sugeina is offline
post #15 of 41 Old 09-22-2012, 10:05 AM
750cc inj, Walbro FP, better TMIC, 3port bcs. And all your maintainence UTD.
