Stage 1, Cobb Intake question - Page 2 - Subaru WRX Forum
post #16 of 22 Old 05-30-2012, 09:52 PM
flashes dont take time to "learn". if they did then i wouldnt be able to go do a WOT run, stop, fix a few things like added or taking away fuel, adding boost, messing with timing etc and then go do another WOT run 3 minutes later. if it had to learn then every run id be losing HP and TQ and not gaining it. same goes with a pro tune. they run it, tune it, run it, tune it, etc. when you leave you have more power than when you came. every reset will set the DAM or IAM to 1. if you start feedback knocking then the ECU will learn it at that spot and pull timing where the fine knock will kick it. if you have fine knock thats basically learned knocked and something needs adjusted. if you pull fine knock long enough and big enough that will cut the DAM or IAM down below 1. thats when you know your having major timing issues but this can still happen 5 seconds after a flash. now getting the DAM or IAM back to 1 without a ECU reset; THIS will take time and a few days to make it happy again. personally i wouldnt want it to go back on its own because something bad happend in the first place and id want to fix it before it happened again.
if it feels like a dog then post up a log and we'll see if anything is wrong.
PS in this heat all your cars should feel like dogs.
post #17 of 22 Old 05-30-2012, 10:33 PM
True enough Scott... a flashed map is immediate. What they're talking about is the realtime map. If you're needing the realtime map to settle in to make the car run good. Then your flash map probably needs adjusted because it shouldn't be that bad right after a flash.
I'm just glad the humidity and heat is going away for a bit here. It was sucking some power out of my car.
post #18 of 22 Old 05-31-2012, 07:45 AM
bad grocerygetter's Avatar
I guess the older cars are a bit different?? When I put mine on the ecu was reset(apparently) with the flash, I'm pretty sure I remember it starting at 12 and moving back to 16 over a few days.(I could be wrong, but I thought that was the case) its been a few months and I have slept since then . But yeah my car has been a bit sluggish lately while temps have been in the 90s. A spray of the ic mister has fixed it up for a bit when I need some extra go go juice I agree though about the log, putpull one and post it up. You have the attention of the right members to help you out man. (Scott)
Now that I think of it after reading this back, I was using a map that was good for both stock or Sf intake. My bad. I did a manual reset to make myself feel better. Good call Scott
Kevin.
Last edited by bad grocerygetter; 05-31-2012 at 07:48 AM. Reason: after thought...
bad grocerygetter is offline
post #19 of 22 Old 05-31-2012, 11:41 AM
Well, it depends on how much was changed with the flash map. I know a few times my car would idle weird after a protune but, my tuner said the real time map just needed to figure that out with a couple minutes of idleing and given a day or two it'd be fine. Other than that though; my car ran like a champ right after a protune.
Sent from my AT100 using AutoGuide.Com Free App
post #20 of 22 Old 05-31-2012, 07:33 PM
wrxPaulie is an unknown
sweet
My AP is in the mail
Will get it here Wed.
Stage 1 93oct Perrin CAI
Should I just put the parts on and load that map
or 1st load the stock intake 93 map
Balls to the wall or what?
wrxPaulie is offline
post #21 of 22 Old 06-01-2012, 05:25 AM
Load the map with the correct intake and call it a day and enjoy it
post #22 of 22 Old 06-06-2012, 03:45 PM
Hi Guys...
Got my AP and I'm loving it.
All I got on the car now is
Nameless axle-back 4" muffler single wall 3.5 tip, quads
Perrin CAI
Stock BpV
Cobb AP Stage 1
Car run amazing, very sharp and I can feel the difference in power delivery, its faster
I'm over boosting little bit ( 16.8 ) should be 15.5 but I'm getting the car dyno tuned.
Not yet, talked with the tune shop and they want me to wait till my car hits 3000miles
and then I will go Stage 2 I'm gonna add cat-less DP, Grimmspeed EBCS
and boost ad A/F gauges.
While I'm there I will stiffen the car little bit with Whiteline sway bars.
But till the 3000 miles hit my car I want to wait, I'm at 1955 so in about a month or maybe later.
Ty guys for all the help
