Stage 1, Cobb Intake question - Subaru WRX Forum
post #1 of 22 Old 05-27-2012, 10:37 PM Thread Starter
nicktown is an unknown
I'm rather new to modifying cars so bear with me if I lack the correct vocab. I have an '11 WRX and just installed the Cobb Intake and flashed the ECU for Stage 1+93. I drove it a decent amount today to test out the feel and the acceleration seems slower. Anyone else experience this? It may just be me overanalyzing everything but it just seems like the car rides "heavy" when accelerating.
Thoughts?
nicktown is offline
post #2 of 22 Old 05-27-2012, 10:52 PM
bad grocerygetter's Avatar
Give it a few days worth of driving. The ecu is probably still learning what's what.
Kevin.
bad grocerygetter is offline
post #3 of 22 Old 05-28-2012, 04:35 PM
WrxCruising's Avatar
WrxCruising is an unknown
Yes as said, give it time, the ecu is pretty much learning the car again to deal with the new modification. How do you like the added intake noise?
WrxCruising is offline
post #4 of 22 Old 05-28-2012, 05:13 PM
Yeah mine did the same thing. Took a week or so of driving back and forth to work(20miles one way) then it was back, plus a little bit on the butt dyno
Kevin.
post #5 of 22 Old 05-28-2012, 09:43 PM
wrxPaulie is an unknown
So After I get my Cobb AP it will take about a week or 200miles
for the ECU to learn the new map and all that?
wrxPaulie is offline
post #6 of 22 Old 05-29-2012, 06:57 AM
Probably not that long, a day or so. You will feel a difference right of the bat.
post #7 of 22 Old 05-29-2012, 08:16 AM
Right. It's gonna vary a bit from car to car. I only say that long because I wasn't checking the dynamic advance multiplier every single day. And when I did it was about 5 days after and everything was as it should be. If you wanna make sure everything is normal, just go into the live data on the ap, and look under the dam, I believe it should be sitting at 1. If so the ecu is probably "happy" with how everything is working.
Kevin.
post #8 of 22 Old 05-29-2012, 09:06 AM
So witht he AP, if I drive the car normal with here and there hard driving
the car should be fine, right?
Its not like its gonna brake or something
Someone on the forum said it will help the car with the tune, much better then stock
post #9 of 22 Old 05-29-2012, 10:41 AM
Correct... But you will still want to get your car a specific tune. The OTS maps are just a generic map.
post #10 of 22 Old 05-29-2012, 05:10 PM
Yeah,
Im talkin with a tune shop here and see what we can do
tyvm
post #11 of 22 Old 05-29-2012, 05:15 PM
1 more question
How long can I drive with the new map before going to the shop
for a proper tweaking?
Will it hurt the car if I don't go at all?
Just upload the map and call it a day
post #12 of 22 Old 05-29-2012, 07:50 PM
I ran my car at stg1 and stg2 for over a year before a protune with no ill affects. I know some people have gone longer. The car will still be rich, but how harmful that is, probably not that bad.
post #13 of 22 Old 05-29-2012, 07:50 PM
I use the ots map and its ok but it has been said by many that the ots maps aren't end all be all. A custom map will be better long term. These ots maps are very generic, you will get more power, a better fuel curve and better drivability, with a custom map. I have been very surprised with this map for my car, and honestly the only reason I haven't gotten a protune is because the closest real tuner to me is in plano tx. Quite a drive for me and that shop is by no means a cheap one.
Kevin.
post #14 of 22 Old 05-29-2012, 09:06 PM
sweet that answers my questions
tyvm guys
I'll hit up again after I get my AP
ty again
post #15 of 22 Old 05-29-2012, 10:11 PM
shaky1 is an unknown
maybe they didnt disable the stability control override. does the traction warning come on when you jump on it?
shaky1 is offline
