Go Back   WRX Forums > WRX Tech Forums > Bolt-on Tech (2008+ WRX)
Old 07-16-2008, 02:27 AM   #16 (permalink)
Reputation: bak2rex is an unknown
08 2 pill
Originally Posted by Longshot View Post
It forms a T from the solenoid, with one hose going to the wastegate and one hose going to the turbo. There is only one pill and it is located in between the T fitting and the nipple on the turbo compressor housing.
To the OP, contact cobb, but you shouldn't be doing anything to your restrictor pill in a stage 2 setup. Are you getting a CEL when it cuts out? Is your cruise light flashing when this happens? With a catless DP the 2.5L engines are prone to overboosting.
i second guessed myself, so i checked. on my 08 there is 2 pill like i mentioned. why? i don't know.anyne else with an 08 please confirm or correct me on this. Maybe my 08 is wrong, but it runs perfect
Old 07-16-2008, 08:40 AM   #17 (permalink)
Longshot's Avatar
Car: 05 WRX
Ok sorry I guess the 08's are different. In that case I know nothing about the setup. So there is a pill in the line going to the wastegate and one to the compressor housing?
DTRacing Tuned
Old 07-16-2008, 08:44 PM   #18 (permalink)
longshot it's all good. it confused me too. I used to own an 04 and this 08 is throwing me all sorts of curve balls..
