Go Back   WRX Forums > WRX Tech Forums > Bolt-on Tech (2008+ WRX)
Old 07-09-2008, 11:27 PM   #1 (permalink)
Reputation: 08silverwrx is an unknown
problems with e-brake
has any one with a 2008 subaru wrx had problem with there ebrake not working at all when pulled up the whole way
Old 07-10-2008, 05:58 PM   #2 (permalink)
Reputation: 08Subie is an unknown
mine likes to sqweel when i pull it if i try and slide a bit on a dirt road, but works fine when parking...can you see if the cable is loose?
Old 07-10-2008, 08:05 PM   #3 (permalink)
Reputation: man show is a helpful contributing member
You might wanna be careful doing that... it's not a very good idea to pull the e-brake while driving an all-wheel-drive car. It's very hard on the gears, and in fact, maybe that's what's making your squealing noise. If you want to whip the back end of a car around, hop behind the wheel of a rear-wheel-drive car and have some fun.
07 WRX - Cobb AP Stage 2
Old 07-18-2008, 04:02 PM   #4 (permalink)
Car: 04 WRX
You may need to readjust your ebrake. There are two ways to do it. One is the cable itself, but the proper way is get underneith the car. Behind each rear brake, on dust shield, there's a rubber tab. Remove it. Using a flat screwdriver, turn the cog all the way tight, the back off by 2-3 clicks. And yes, it's a lot easier then it sounds. You can double check the repair manuel to do it yourself, or have a mechanic do it for you.
As for yanking your ebrake while moving. It is quite bad. From what I understand (hearsay) on an STI is okay since it has a sensor that disengages the rear diff when you do it. On a regular WRX, you're locking up your rear diff and heats it up pretty badly since all the stored energy is going into the diff.
RIP Colin McRae
