Perrin Exhaust Help!!!! - Subaru WRX Forum
post #1 of 6 Old 04-16-2010, 01:39 AM Thread Starter
wrx1398 is an unknown
Does anyone have any ideas why my exhaust hangs to the right???? . !Cry!
the right tip is about 3 inches lower than the left. The left has absolutely no play with the bushings and the right seems to be super loose. I thought it was the fitment of the stock dp and the cat back but just installed the perrin dp today and its still the same way.
I hope that made sense
Thanks for any help
wrx1398 is offline
post #2 of 6 Old 04-16-2010, 08:12 AM
It almost looks like its bent, did you back into something? If not I would loosen all the connections and try to center it up.
nagyhead is offline
post #3 of 6 Old 04-16-2010, 05:39 PM
...if it's bent, I'd imagine you could bend it back, right? Just bend the hangers gently a little at a time until you get it where you want it.
post #4 of 6 Old 04-18-2010, 06:36 PM Thread Starter
No i didnt back into anything thats fresh outta the box. . . never thought about bending the hangers haha but do you think new urethane hangers on the low side would help with pulling it up? plus i tried loosing everything and trying to re-align it and when i tighten it back up it goes right back.
wrx1398 is offline
post #5 of 6 Old 04-18-2010, 06:38 PM
A quick fix, and not permanent, would be putting a hose clamp around the urethane hanger on the low side and tighten it until it's even. At least then it will look normal until you can get it fixed.
post #6 of 6 Old 05-04-2010, 06:46 PM
soup_notzee is an unknown
it almost looks like your right side is just bolted up wrong. I have the perrin CB as well, and had no problems. I guess what I'm getting at is that if you see how the tips are slanted from the muffler, the right one looks as if the slant is aimed down instead of fitting properly. if that makes sense at all.
soup_notzee is offline
