-   -   passenger door locks will not open - looking for the best locksmith (http://www.wrxtuners.com/forums/f121/passenger-door-locks-will-not-open-looking-best-locksmith-33566/)
Twandalu 02-06-2013 05:46 AM
I have my 2004 Subaru Impreza WRX, and my car passenger door will not open i tried many times by inserting key to unlock it but no luck. It seems that the cable broke at the door latch but not sure. so i need a locksmith who can fix this issue if anyone knows about it kindly suggest me from here.
pzr2874 02-06-2013 07:03 AM
Not many locksmiths will fix the issue, they will pop the lock, but not the mechanical fix.
Try a mechanic if you aren't inclined to tackle it yourself.
Good luck
FrankRodrigue1 01-20-2017 12:37 AM
There must be problem with the solenoid because solenoids in each of the doors that activate the door lock mechanism.So there must be problem with the wiring. So [URL="http://www.emilylocksmithcoralgables.com/"]Locksmith[/URL] can't be able to repair this you should visit mechanic to fix that issue.
RoboTuner 01-20-2017 10:26 AM
If your solenoids fire then it's not electrical. Sounds more like you need to pull the panel off and either lube or replace the linkage inside. After I got my wagon painted the passenger front door handles wouldn't go back in and when trying to lock/unlock the door it wouldn't always work.
You will need to either remove the dash to allow enough room to pop the panel off or take it to the dealer.
