new to subaru - Subaru WRX Forum
post #1 of 9 Old 07-05-2012, 04:19 PM Thread Starter
new to subaru
Hi im new to owning a subaru been trying to search and learn about them and see that we pretty much need a tune for any modification so i thought id ask if i put in a k&n drop in filter a full 3inch catback exhaust on my 2012 wrx and reset the ecu by disconection the battery i would not a tune because im still using the stock airbox and all a exhaust does is frees up backpressure correct? If u could please verify me that would be awsome thanks
dudemandude is offline
post #2 of 9 Old 07-05-2012, 04:55 PM
Drop in is ok. Resetting is ok as well. Not sure if the CB does much of anything but sound, but mated with a aftermarket DP will help relieve the backpressure for sure.
post #3 of 9 Old 07-05-2012, 06:29 PM
unhook your neg. off your battery and press your brake in for 10 seconds or so to drain all power. That should reset ya if needed.
post #4 of 9 Old 07-13-2012, 01:33 PM
Why do you need to do the reset?
bhuebs is offline
post #5 of 9 Old 07-13-2012, 04:56 PM
^Normally it's a good idea to unhook the battery when doing any changes to your car. Plugs, exhaust, cleaning the TB, cleaning the MAF, anything mech/electric based really.
post #6 of 9 Old 07-13-2012, 07:00 PM
Okay thanks for the info pzr! I didnt do that when I put my CBE on. Could that cause my CEL to come on? Mine came on the other day when I was ideling in traffic. It kinda started to sputter and then came back to normal idle. In the process it caused the CEL to come on.
bhuebs is offline
post #7 of 9 Old 07-13-2012, 07:35 PM
^Make a thread..... It could be anything....
@bhuebs
BTW... nice user name
post #8 of 9 Old 07-13-2012, 07:46 PM
Don't waste money and time with a cat back...Truthfully it's a waste unless you are going with a full turbo back.
As far as the CEL, go to an auto parts store and have them run a diagnostic on it and it will tell you what it was for. Probably just a misfire..
post #9 of 9 Old 07-14-2012, 01:01 PM
@bhuebs
I already did. Wasn't getting much on there. Haha thanks bud
bhuebs is offline
