my 08 rex and the TD04 turbo - Subaru WRX Forum
post #1 of 11 Old 09-11-2010, 09:54 PM Thread Starter
daniel5on is an unknown
Just wondering if its worth building with this turbo or should i look at switching it out for a VF serious , been doing some reading and apparently the TD04 is pretty small compared to the VF52 in the 09+ wrx ....
I plan on getting a high flow catted down pipe , possibly un-catted ( just want to avoid the exhaust carbon on my bumber since i have a SWP rex) , and an invidia n1 exhaust of something similar to start , then ELH ...
BTW flashed my car to stage 1 and what a difference from stock , at least it seemed huge to me...
edit : just read ELH sort of quites down the boxer rumble , who wants that!
Last edited by daniel5on; 09-11-2010 at 10:02 PM. Reason: edit : just read ELH sort of quites down the boxer rumble , who wants that!
daniel5on is offline
post #2 of 11 Old 09-11-2010, 11:36 PM
Depends on your budget and what you want out of the car. Some people do everything but the turbo (leaving the TD04) because it spools so quickly. But on the down side you wont make very big number with it, so it will die out very quickly on the top end. Personally there are other turbos that spool quickly enough and provide much better range of usable power out there, that its definetly worth upgrading the turbo.
post #3 of 11 Old 09-11-2010, 11:37 PM
no it's not worth it...just get the VF or bigger
post #4 of 11 Old 09-12-2010, 04:23 PM Thread Starter
newtothegame - what do i need to look into if i wanna run a VF series?
post #5 of 11 Old 09-12-2010, 06:40 PM
you would need nothing except a tune to just run it, but to maximize it's potential a larger intercooler and a turbo back exhaust are a must
post #6 of 11 Old 09-12-2010, 10:00 PM Thread Starter
i do plan on doing a full turbo back first before upgrading the turbo , looking at either invidia or TurboXS since they are the only ones ive found to do dual exhausts ... any suggestions where i should look to get the best deal?
post #7 of 11 Old 09-14-2010, 04:27 PM
anxiouz's Avatar
anxiouz is an unknown
Personally, I've always done turbo's last on my cars. Because by then you'll already have mods to support it properly and you'll get the most out of it. If the turbo is working fine then do the other stuff first. Then replace it last...it'll give you the time you need to do adequate research on what turbo to get.
But if I had an 08 WRX I would def add a new turbo to the mod list. A VF for sure, maybe bigger if you want more.
anxiouz is offline
post #8 of 11 Old 09-20-2010, 10:15 PM
Wutangjn12's Avatar
Wutangjn12 is an unknown
i have been running stage 2 on my 08 for over a year and let me tell u, nothing beats all the torque the car makes i havnt gotten a dyno but considering what ive run, i would imagine im making around 340-360 wheel torque believe it or not
Wutangjn12 is offline
post #9 of 11 Old 09-21-2010, 12:39 AM
Ducks is an unknown
It would be crazy if you where making that much TQ with a stock turbo. Can i see you current mods on the car.
Ducks is offline
post #10 of 11 Old 10-10-2010, 07:02 PM Thread Starter
well ill get started like i said with the CBE move on to headers... Later on im looking to build the internals as well... I want around 350hp.
I know somewhere down the line ill have to get injectors and a new fuel pump but thats 6 months to a a year from now.
post #11 of 11 Old 10-10-2010, 08:39 PM
its possible but way harder for his stock turbo over the VF52. not sure if he upgraded though.
