I've finally decided on my current goal is to maximize the output
I can get from the stock 09 WRX turbo.
The downpipe/tmic had done well to improve power but also increased
the boost taper effect at 5000+rpm. I would like to remove some of this
boost tapering and get the most out of the stock turbo without pushing
the turbo beyond its safe limits.
The things to achieve this are for sure a fuel pump upgrade. I have had
mixed opinions on injectors so I would like more input on this. For instance
if I should upgrade injectors, what size do I get? Can anyone post/email
me links to a vendor I can pick these up from?
This leads me to a question regarding the boost control solenoid. If I do
injectors + fuel pump, do I require a new EBSC?
My protune date is coming up and I am hoping to get the rest of these
mods done so I can have just a single protune to get the most out of
my turbo since this is how it will remain for a while.
I've had mixed feelings about upgrading my injectors... I was told by the guys at cobb that I don't need to at my elevation and crappy fuel area (I live in Utah). If you're at a lower elevation and can tune for 93 octane it seems to be necessary.
Tearing apart a brand new car because I love it
Check out boost addicts thread. His 08 is using our turbo. He has all the info you'll need.
Oh thanks, I didn't realize he had the same turbo as the 09s currently. The latest stuff I read on his post was the new turbo he was trying to decide over getting. His mod list was pretty extensive too though so I may have written it off to quick to use as a sort of example.
Thanks for this. I live at pretty much sea level, not even 300ft on average. But the best gas we have around he is 92 octane.
The calculator is telling me around 560cc at 90% assuming 320whp or 700cc assuming 400hp crank. So guess it seems I would probably need a 650 or 700cc for 320whp/400crank?
I'm making the assumption that the calculator is going by crank hp.
Get bigger than what you think you need, just for the head room, or even in case you decide later on to go for more power. DW injectors are amazing. Im running 850cc with 326AWHP, car still drives like stock.
lucky....
-Randy
750cc is more than sufficient for the vf52. Last time we checked injector duty cycles were in the 60% range. On the bigger turbo, I'm keeping the 750ccs.
I would also upgrade the fuel pump to the walbro 255lph to future proof yourself.
The Perrin equal length header is a pretty awesome piece of work if you are okay with the sound change. Your spool up will be significantly quicker and your mid-range punch will be tremendous! Unfortunately there isn't much you can do to alleviate the tapering/plateauing effect of the VF52 in the upper rpm range. It's simply unable to push enough air to continue making power.
I would second Boost's suggestion to the header. It's easy to do, it does give you a nice kick in the pants. the biggest downside is the different exhaust note...
Also what about an intake(if you don't have one already)? Since you are getting it tuned..
Was told and read in other places that the 2009 wrx intake is good for 350whp and to not worry about upgrading it unless I go past that. Information suggests I'm going to peak at 330-340whp on the turbo anyway so a 5-7hp gains from an intake isn't really worth the money for my goals I'm thinking?
And as far as the exhaust, No matter what I do, I can't do headers. To me the iconic scooby sound is just irreplaceable at any power level I'd put NO_2 on the car before I'd consider replacing headers
I dont know if they are working on it (for the 08+). But have heard great things about grimmspeed and their PnP'd manifold(s) and crossover pipe. It allows you to keep the subie sound, but also increases effeciency of the parts. Just something to think about or look into also.
Thought I should update this tread with my progress for future forum searchers.
Just got back from my pro-tune with a grin on my face.
Thought I would share some pics and results of the dyno tune session.
I'd like to thank Tim at Cobb Tuning Surgeline for his time in Portland, Or.
Tuning was done on a mustang dyno. Also thank you to some members of
the forum for answering some of my questions.
2009 WRX hatch
3" Cobb downpipe
Perrin top mount intercooler.
Walbro 255 pump
slightly modded non-catback exhaust sums up the list of supporting mods.
Final tune was 18 PSI map,
300 awhp (didn't grab a picture of the 302hp & 326ft-lbs),
325 ft-lbs torque,
Very nice =D Looks good to me. I bet it feels a heck of alot better to let the gas pedal hit the floor and get mashed into your seat too, lol. Now, from what I see missing on your mod list, you will definitely need a short throw shifter and bushings to get ahold of that beast! Have fun and be safe up there since Winter is hitting in
Although he's running an FMIC, I'm curious what your numbers are with the TMIC, once you get a few more mods.
The tuner (Tim) told me I would get some better power with a catback. Might spring for that soon. I did some of my own tuning adjustments to the stage 2 maps just to get me by for a couple weeks before the dyno session. He said it wasn't bad. But it also had a big dip in torque. I was just tuning it to get it to hit target boosts better, and he really made it come alive with over 22hp and 30ft-lbs extra torque over my adjustments. I will have to look at the before/after to really see, but he did great. The car pulls so much stronger now that its almost hard to enjoy the power in anything below third gear since your too distracted by your head bouncing off the head rest.
