Just went crazy at SPT store. - Page 2 - Subaru WRX Forum
post #16 of 23 Old 06-10-2010, 01:12 PM Thread Starter
Got it. Thanks for the heads up.
wrx265_8 is offline
post #17 of 23 Old 06-10-2010, 02:03 PM
Originally Posted by VisiX View Post
With a torque wrench. For the bolts on the subframe you'll be torquing to REALLY F***ING TIGHT (184 lbft). For the other bolts you'll be torquing to normal tightness and then a little tighter (40 lbft).
Oh man if you think the 184lbtq subframe bolt is tight, my old VW bugs flywheel was factory torqued to 350lbtq.
The SPT short throw is pretty exspensive, whats the differnce between that and like the kartboy or the COBB short throw which is considerably less exspensive?
808subbie is offline
post #18 of 23 Old 06-10-2010, 02:07 PM
^^welcome to OEM vs. aftermarket. Aftermarket are even shorter throws
post #19 of 23 Old 06-10-2010, 02:14 PM Thread Starter
It's more expensive because your buying the whole assembly instead of just the lever part. Don't ask me why they do that. They giving it to me for 221. and its got a warranty and if for some crazy reason it does cause problems with the other components, subaru will fix it.
wrx265_8 is offline
post #20 of 23 Old 06-18-2010, 06:49 PM Thread Starter
Got the CBE on today and just took it for a test drive. The sound is just what I was looking for. It seems louder by a couple db inside and has a much deeper smooth purr on the outside, but not much louder than the stock. Acceleration in first and second has improved. This after I went stage 1 with the AP. What a difference that made. Now my car sounds like it actually wants to be running.
wrx265_8 is offline
post #21 of 23 Old 06-18-2010, 06:53 PM Thread Starter
my new momo nob is perfecto. I got the round steel and black cushioning one. Says momo subaru on the top. Feels so much better than the stock. Looks so much better than the stock. Now I feel like I don't even need a STS.
wrx265_8 is offline
post #22 of 23 Old 06-22-2010, 08:16 PM Thread Starter
Just put the front strut tower bar on. After a good test drive through plenty of turns I've noticed a couple things. The front stays much more level during turns. On straightaways it seems more stable and less likely to turn with out my input. Steering response is sharper.
wrx265_8 is offline
post #23 of 23 Old 06-23-2010, 01:22 AM
AMG
What size is the SPT exhaust? Is it 2.5 in?
AMG is offline
