IPR TMIC Intercooler - Subaru WRX Forum
post #1 of 17 Old 01-22-2012, 10:18 PM Thread Starter
NDS WRX's Avatar
NDS WRX is an unknown
Pix of IPR TMIC in 2011 wrx.
Installation took about 3 hr. used the Tomioka Racing Throttle Body Hose,
T-Bolt Hose Clamps and some longer bolts for the turbo. The IC fits very tight but for $435 i think its worth it.
Stage 2
311WHP 352 TORQUE
K&N intake
Turboxs BPV
3" Dp
IPR TMIC
Invidia Q300 Exhaust
NDS WRX is offline
post #2 of 17 Old 01-23-2012, 10:36 AM
thepants1337's Avatar
thepants1337 is an unknown
Looks nice,
Any details on how much PSI this can hold or the before and after on hp/tq numbers? Noticeable difference before and after? And for that price it seems pretty nice.
thepants1337 is offline
post #3 of 17 Old 01-23-2012, 11:01 AM
It's not feasible to ask "how psi it can hold" nor can you expect an answer to before and after as every setup with net completely different results. Being noticeable depends on the setup and how you use it.
A TMIC is not a power mod, it's a support mod for your power mods.
post #4 of 17 Old 01-23-2012, 11:17 AM
With that in mind! Would it support 420ish whp?
post #5 of 17 Old 01-23-2012, 11:17 AM
Grats on 666 posts. lol
post #6 of 17 Old 01-23-2012, 11:26 AM
I doubt a lot of TMICs could help create 400 whp unless you're using meth, E85, or CO2 sprayers on the TMIC.
post #7 of 17 Old 01-23-2012, 11:34 AM
BoostinChick is a helpful contributing member
I like how it uses the stock mounting locations for the turbo and BPV. A friend of mine has an 08' WRX with the Process West, and although it's big and shiny, the way the hoses route I dislike. It also shifts the BPV over about 2-3" making that plumb back for the BPV to the intake mani super stretched.
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #8 of 17 Old 01-23-2012, 12:38 PM
-------Offtopic-----------
Just realized all the reply posts were from PA drivers. <3 lol
post #9 of 17 Old 01-23-2012, 12:45 PM
brfatal is from Texas...unless his profile is lying.
- Sandra
post #10 of 17 Old 01-23-2012, 12:53 PM
Sure, but for that much it won't exactly be ideal. You'll want to look into a FMIC.
Sorry for the the thread jack.
[edit] It is lying. I'm in VA.
post #11 of 17 Old 01-23-2012, 01:40 PM
An the OP is not from PA either....
post #12 of 17 Old 01-23-2012, 02:35 PM
Emphasis on "reply" and also an apology to brfatal, but VA is close enough
post #13 of 17 Old 01-24-2012, 12:31 AM
Why did it take 3 hours to install it?
Kjott21 is offline
post #14 of 17 Old 01-24-2012, 06:42 AM
^Are you saying it should have taken less time because it fit so well?
post #15 of 17 Old 01-24-2012, 11:03 AM
My Perrin TMIC is huge and it only took about 2 hours to install. Probably about 15 mins to take it off the STI TMIC and about 5 mins or less to put the gaskets and install the y-pipes from the old TMIC to the Perrin. So, 20 mins tops on removal and setting up the new TMIC. The rest of the time was bitching and cursing trying to get the larger TMIC back in there correctly. But, I got it in there finally. Man, I remember being so mad that its a lot harder to get on then it was to get off. But, the new WRX TMICs look a lot easier to install to me.
