-   -   Intake question (http://www.wrxtuners.com/forums/f121/intake-question-43489/)
pjkatz04 01-06-2014 10:42 AM
Intake question
Hi. So took the plunge and did stage1+SF. The intake noise in the cabin -- air swooshing -- if very noticeable esp under boost. Is this normal? I'm just afraid there's a leak somewhere.
Tia
Pete
thekamikaze kid 01-06-2014 10:55 AM
its normal. the intake makes the turbo louder. enjoy the coolness, :D
turmic 01-06-2014 11:40 AM
If it's hooked up right, then you're just hearing air in the new intake vs the factory setup.
thekamikaze kid 01-06-2014 11:51 AM
Increased Induction Sound
Enjoy the increased snarl from your engine and hear the turbo spool more clearly with the addition of the COBB Tuning SF Intake system. Turbocharger induction noise and bypass valve venting sound is much more audible using this intake system.
brfatal 01-06-2014 12:42 PM
It's pretty inconsistent. Sometimes an short ram intake will make noise, sometimes it won't. I've had 2 different ones over the years and one is dead silent while the other was annoyingly loud. You really shouldn't have any leaks if you installed it correctly. Intakes a pretty straight forward on the install.
The cold weather is probably contributing to the noise as well.
psinuse 01-06-2014 02:37 PM
No your car is ready to blow up...
BLAZE2099 01-06-2014 06:16 PM
If it had a bad leak, your car wouldn't run.
dukefist 01-06-2014 09:09 PM
[quote=pjkatz04;421049]Hi. So took the plunge and did stage1+SF. The intake noise in the cabin -- air swooshing -- if very noticeable esp under boost. Is this normal? I'm just afraid there's a leak somewhere.
Tia
Pete[/quote]
What intake did you go with? Deciding which to go with myself.
pjkatz04 01-06-2014 10:56 PM
Cobb. The only real option for wrx.
pjkatz04 01-06-2014 10:58 PM
Ok cool thanks everyone. Yea I've had other intakes and they didn't sound like this. But then again all my other vehicles were NA and not forced induction. By the way--stage 1+SF is like adding a fifth cylinder.
arewmors 01-07-2014 05:57 AM
[quote=pjkatz04;421353]Cobb. The only real option for wrx.[/quote]
FYI, AEM intakes are also an option for the newer gens. They have OTS maps for it as well.
AEM is a true CAI not a short ram like Cobb.
